Rocker pivots
Old May 5, 2017 | 01:49 PM
Jimmy946's Avatar
Rocker pivots
I have a 1971 cutlass supreme with a 350 rocket. I am new to olds so I have never encountered rocker pivots. My question is I purchased comp cam roller rockers hydroulic lifters and a new cam and was wondering do I have to use the pivots on there??
Old May 5, 2017 | 02:40 PM
don71's Avatar
same but different
No, but those roller rockers you bought need to have the right size stud and thread size. Hopefully you got the right ones..I think the 1441 kit is the right one. Sometimes the push rods length may not be correct but it all depends. If you only purchased the arms, you are not done buying stuff yet.
That other stuff you'll remove and just throw...in a box, after you have what you need.
What exactly did you buy? part numbers...
And welcome to Classic Olds.
Old May 5, 2017 | 02:45 PM
CRUZN 66's Avatar
Olds Fever
Welcome to the site... No, the stock pivots would not be used with the comp cam roller rockers...
Old May 6, 2017 | 12:34 AM
Jimmy946's Avatar
I purchased comp cams 1441 kit part # 249-1441 with rockers, studs and push rods and Edelbrock performer plus camshaft - edelbrock 3713 part number 350-3712. I haven't Played with motors in over 20 years and they were all chevy. What is the best way to adjust the valves I used to do top dead center take the play out and another 3/4 turn is that what I should do with this set up?? Thanks in advance
Old May 6, 2017 | 10:58 AM
edzolz's Avatar
There is no adjustment for stock Olds lifters. For yours, turn over the engine by hand so each set of rockers is where the valve is closed all of the way. Tighten down the nut until the push rod will not spin by hand. Tighten one half more turn and go to the next valve that is closed. That is how I do it, there are others with different methods.
Old May 6, 2017 | 12:35 PM
RROLDSX's Avatar
You will have to check your pushrods lengths for proper geometry and you may need to exchange your push rods for longer or shorter. You will need an adjustable push rod to check for the proper length required. Depending on the cam grind, head gasket thickness, head shaving, rocker arm design and spring height can all change the geometry. There are several instructional videos on Summit Racing, Comp Cam and Youtube.
Old May 23, 2017 | 10:33 AM
Jimmy946's Avatar
Does anyone know what exhaust donuts (part number)go on my 1971 cutlass 350 rocket when I bought the car it was in peaces and they didn't come with the car. A guy at napa gave me some that he thought went on the car but I don't believe that are the correct ones since they crush when I tighten them down
Old May 23, 2017 | 02:31 PM
don71's Avatar
same but different
You shouldn't need a doughnut style gasket. This joint is usually metal to metal no gasket. Some of the big block manifolds use a flange gasket, one side is a flange the other doughnut like. Some 307 use a doughnut but yours should not.
Old May 25, 2017 | 08:11 AM
Jimmy946's Avatar
i have the one that is half flange half donut but it just don't seem right
Old May 25, 2017 | 11:24 PM
11971four4two's Avatar
MOTORHEAD
I thought there was a torque to foot pound # on the rockers???
stock configuration
Old May 27, 2017 | 11:10 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Stock configuration is tighten to 25 ft/lbs, I usually tighten the pair evenly together. I personally like the stock set up, which fine for cams that are not too radical.
Old May 27, 2017 | 12:19 PM
The OP doesn't have stock rockers, he has Comp Cams 1442 roller-tip rockers (this is what comes in the 1441-kit). Read the instructions that come with the rockers - they tell you exactly how to adjust them. I ASSUME the OP has installed the necessary studs and guide plates, right?
Note that the 1442 rockers use ball pivot, just like a Chebby.
Arrowstorm
Jan 27, 2015 03:38 PM
442bob
Nov 9, 2011 04:31 PM
CutlassLegend
Sep 21, 2011 02:56 PM
