Need Input- 1/4 Mile & Trap Speed
Need opinions. Building a 67 Olds w/455. What 1/4 mile time & trap speed is reasonable for this build: 3200lbs (lightened), 440hp 468ci (.060 over), built 200R4 (steeper 1st gear, OD, etc), 3.55 axle w/Eaton posi, and a set of Mickey Thompson Sportsmans (L60s rear and 225/70 front)? What 1/4 time & trap speed should this combo be able to attain?
440 crank shaft HP has the potential to run 121.5 MPH @ 3200 pounds. 1320/121.5=10.86 ET. Now the question is: will the OD trans let you reach that potential, I don't think so, but the results will be interesting. I will say high 11s to 12s.
HMMMM the big question is how efficiently can you put the power down. I ran 12.20's with about 360 HP from a 355 olds and I know I was leaving some on the table but the 360 HP was based off of the 1/4 mile trap speed and weight. Hit the track and get some base numbers.
That sounds more the rear wheel HP to me....
440 crankshaft hp in a 3200 pound car will run 11.87 @ 120.75 mph at sea level.
Use this link for estimates.
https://robrobinette.com/et.htm
