Can you tell what brand these are
Old Feb 5, 2019 | 07:36 AM
young olds's Avatar
These popped up on my local Craigslist, guy selling them does not know much about them. Look like knock offs of the nice Harland sharp with the common shaft. They are cheap enough, if they are a known good rocker to use i will pick them up. He said he had guide plates as well but I was under the impression you did not need them with shaft mounts.
Old Feb 5, 2019 | 07:53 AM
They look like Harland Sharp.
Old Feb 5, 2019 | 08:02 AM
young olds's Avatar
The Harland’s I have seen had a smaller common shaft and nicer looking adjustment screws for valve lash.
Old Feb 5, 2019 | 08:08 AM
young olds's Avatar
These (not these exact ones but the smaller shaft) are the ones I am use to seeing but while looking for this picture I found a picture of a set that looked exactly as above and said they were Harland’s.
Old Feb 5, 2019 | 09:30 AM
Inline's Avatar
That set you last posted a picture of, is in sale on oldsrocketparts, without zero mentions about them being HS ( and i bet they would mention they are HS rockers if they really would be), and the price they are listing for those, is 224$, which also suggests they are not genuine HS's.
Old Feb 5, 2019 | 11:53 AM
young olds's Avatar
so you think the original post are Harland’s and second picture are the knock offs? If so I am definitely picking them up.
Old Feb 5, 2019 | 12:22 PM
Inline's Avatar
Honestly no idea. I just knew ive seen something similiar than the pic i referenced, and searched it up to point it for you/ someone else for reference purposes.
Old Feb 5, 2019 | 01:15 PM
Bernard Mondello's Avatar
The very top picture are second generation Mondello shaft bolt on roller rocker arms.
the original design was different in design and purple in color...
Bernard Mondello
Old Feb 5, 2019 | 03:30 PM
young olds's Avatar
Bernard Mondello
Are they a good rocker arm? Geometry, strength, stability, etc?
Old Feb 5, 2019 | 04:20 PM
Those rockers were made by Harland sharp and are for stock cast iron cylinder heads with stock length valves...
These were made about 30+ years ago, but if in good shape will last a lifetime.
If you have longer valves you must shim the pedestal accordingly!
Bernard Mondello
Old Feb 5, 2019 | 07:18 PM
young olds's Avatar
I am running iron heads with stock valves. Guy is asking $200, good buy for these old rockers?
2blu442
Mar 20, 2019 01:34 PM
deaddds
Feb 18, 2019 07:42 AM
72455
Dec 25, 2018 01:22 PM
meoff
Aug 12, 2018 11:00 AM
dele
Jan 19, 2017 01:14 AM
