clutch package
Old Jul 31, 2017 | 08:44 PM
jwr7042's Avatar
clutch package
what clutch and pressure plate would you recommend for 455 with some build. mostly for street but may make a few passes at the track.
Old Jul 31, 2017 | 09:56 PM
shiftbyear's Avatar
I would talk to a tech rep from each mfg. you are considering. There are so many out there I get confused. I've had good luck with Mcleod and Ram clutches. It's been awhile since I've rowed any gears. Good luck.
http://www.ramclutches.com/contactus.html
https://www.mcleodracing.com/content...-instructions/
Old Aug 1, 2017 | 06:07 AM
Run to Rund's Avatar
I am using South Bend Clutch. Mine is more strip than street, but does both. They can build whatever you need.
Old Aug 1, 2017 | 01:18 PM
jcdynamic88's Avatar
i have had good luck with ram,i make a couple trips to the track a year but mostly street driven.no leg shake in traffic and holds up to slicks on sunday.i am using the street/strip package.
RandyS
Jul 6, 2021 07:45 PM
47 Convertible
Apr 3, 2014 07:56 AM
RandyS
Mar 8, 2014 05:07 AM
tpkj
Feb 2, 2005 01:17 PM
