no baffles, valve covers
I have roller rockers and the valve cover baffles removed completely. I have the 2 breathers attached to the oai air filter. I obviously have alittle oil in the air filter housing, Is this an issue?
Also the intake rubber 90. That connects vacuum to the carburetor is leaking oil. So im assuming there is no valley pan?
The engine has been built before me, with not allot of miles on it, the oil pan was modified, looking in the oil passages cleaned, roller cam/ rockers. So maybe theres a reason the valley pan isnt on..
How about this---My race car smoked out one header for a whole season and I thought I checked/changed everything without getting into the motor which ran fine. Turned out I had switched the valve covers from left to right and one of the rockers was flipping oil right up into the opening for the evac hose. I haven't seen those pans under the intake used in years but I suppose they use them on stock engines. We currently use a Victor manifold and have a pcv valve tapped right into the valley and into the manifold right under the carb----zero oil leaks anywhere.
If you find your using a bunch of oil then you need to do something. If its just a small amount just wipe it up periodically. Most do not use the turkey tray with roller lifters because they need to be trimmed.
Yes, that is not a vacuum port, it is for a pcv valve, and should be connected to the large nipple on the carb baseplate. You could pull the intake and install a modified turkey tray, or valley tray which would keep the oil off the bottom of the intake.
RAMBOW
March 20th, 2017 06:58 PM
