Hard Knocks
Old Nov 4, 2020 | 04:07 PM
fleming442's Avatar
Old Nov 4, 2020 | 04:18 PM
scrappie's Avatar
Wow!
Old Nov 4, 2020 | 06:10 PM
RetroRanger's Avatar
72 Olds CS
ouchy i guess you were not at idle speed?
Old Nov 4, 2020 | 06:40 PM
fleming442's Avatar
Old Nov 4, 2020 | 07:10 PM
coppercutlass's Avatar
Chevy budget Olds powered
Oooooffff that's a tough one.
Old Nov 4, 2020 | 07:15 PM
Valve float I assume.
Old Nov 4, 2020 | 07:57 PM
fleming442's Avatar
Old Nov 5, 2020 | 02:43 AM
VORTECPRO's Avatar
"How does that even happen?"
Harmonics
Old Nov 5, 2020 | 03:32 AM
fleming442's Avatar
Old Nov 5, 2020 | 03:33 AM
Oldsmaniac's Avatar
Sucks, but now is your chance to build an even better one! We can build it, better, faster ...stronger. I see to have heard this before! lol
Old Nov 5, 2020 | 05:56 AM
VORTECPRO's Avatar
in the bead rolled sides of an oil pan of a fully balanced engine? Sounds like a poorly designed product to me.
Thats possible, but I did see a awful lot of holes drilled in your crank, that always makes me nervous.
Old Nov 5, 2020 | 11:39 AM
fleming442's Avatar
Old Nov 5, 2020 | 04:01 PM
VORTECPRO's Avatar
Correct as the rods and pistons get lighter weight has to come out of the counter weight side of the crank. But the correct way to remove weight is to cut the counter weights down, this leaves you with less holes which can hold oil.
Old Nov 5, 2020 | 06:12 PM
fleming442's Avatar
I can appreciate that, plus you're concentrating the weight closer to the centerline. In a perfect world with unlimited funds.....
Old Nov 6, 2020 | 10:15 PM
Battenrunner's Avatar
Sorry to hear about this happening.... really stinks.
So, what is your plan? Is it in the cards to do a new build with all new parts, starting over?
Old Nov 7, 2020 | 05:26 PM
fleming442's Avatar
Old Nov 8, 2020 | 04:47 PM
TimMC's Avatar
ouch that just makes me cringe. Give opportunity to start fresh????
Old Nov 12, 2020 | 06:58 AM
fleming442's Avatar
Old Nov 12, 2020 | 07:06 AM
VORTECPRO's Avatar
For those asking "why aluminum rods?" 1308g unofficial bobweight plus a rod bearing, that's why.
That is not your bob weight. How much does the rod weigh? I would bet your bob weight will be around 1800-1900 grams, But that is fairly light for a Olds, but then then again how reliable is a aluminum rod in a street strip car?
Old Nov 12, 2020 | 12:12 PM
fleming442's Avatar
Old Nov 12, 2020 | 05:33 PM
VORTECPRO's Avatar
Hence, "unofficial"! 🤣 the rod alone is 607g
I've got 12,000 miles on it with probably 25-30 passes. Bearing wear was minimal. Is there a problem?
Ok, so lets look at the math.
820 grams approx Piston, piston rings, wrist pin, locks
175 grams approx small end of rod
995. Total
432 grams big end of rod
55 grams rod bearing
432+55=487X2=974+5=979
979 total
995+979=1974 Bob weight. For example the last 455 with steel rods I built had a 2120 gram bob weight.
This should be close to your bob weight. Theres no problem until one of those rods breaks, hopefully that doesn't happen, I know on our race cars we replace them after 150 passes. I've been told people have been running them on the street, I guess oil temp is important. What weight flywheel do you run?
Old Nov 13, 2020 | 05:41 AM
Bubba68CS's Avatar
The problem with aluminum is it doesn’t have a fatigue limit like steel does. Meaning no matter how low the stresses are, it will eventually fail from fatigue. Steel, in theory, can be designed to never fail from fatigue (in practice there are always microscopic flaws that will eventually cause failure, but nowhere near as soon as aluminum).
So by running the engine on the street, you’re putting fatigue cycles on rods that have a limited number of cycles before breaking.
One reason they tend to be limited to race cars is that it’s much easier to keep track of use. Street driving has variable loading that makes it more difficult to know when they’ll fail than the predictable environment of racing. Aluminum rods are essentially a maintenance item.
Old Nov 13, 2020 | 11:13 AM
fleming442's Avatar
Did I miss all the rod failure threads? Seems to be a bunch of theory and speculation. I'll let you know when I break one. Later, fvcknuts!
Old Nov 13, 2020 | 11:33 AM
Bubba68CS's Avatar
Apparently - there are plenty out there.
Yes...theory taught to every engineer on the planet who designs every piece of machinery you've ever directly used or indirectly benefited from.
Best of luck. Hopefully they're built for an absurdly higher power mark than you're putting out.
Old Nov 14, 2020 | 05:53 AM
This is strange, what happened to this thread??
Old Nov 14, 2020 | 12:37 PM
Bernhard's Avatar
That sucks!
Good luck with the new engine build.I don't know of anyone that beats on there engine without eventually hurting it.
Thanks for sharing and the heads up on the importance of valve spring choice and maintenance.
71OldscutlassS
Oct 8, 2023 05:51 AM
67Olds442X2
Oct 20, 2019 10:15 AM
Mikesmith455
Aug 11, 2018 10:00 AM
Cutlass71s
Aug 18, 2017 05:25 AM
firefrost gold
May 16, 2015 04:47 PM
