Hard Knocks
Correct as the rods and pistons get lighter weight has to come out of the counter weight side of the crank. But the correct way to remove weight is to cut the counter weights down, this leaves you with less holes which can hold oil.
That is not your bob weight. How much does the rod weigh? I would bet your bob weight will be around 1800-1900 grams, But that is fairly light for a Olds, but then then again how reliable is a aluminum rod in a street strip car?
820 grams approx Piston, piston rings, wrist pin, locks
175 grams approx small end of rod
995. Total
432 grams big end of rod
55 grams rod bearing
432+55=487X2=974+5=979
979 total
995+979=1974 Bob weight. For example the last 455 with steel rods I built had a 2120 gram bob weight.
This should be close to your bob weight. Theres no problem until one of those rods breaks, hopefully that doesn't happen, I know on our race cars we replace them after 150 passes. I've been told people have been running them on the street, I guess oil temp is important. What weight flywheel do you run?
So by running the engine on the street, you’re putting fatigue cycles on rods that have a limited number of cycles before breaking.
One reason they tend to be limited to race cars is that it’s much easier to keep track of use. Street driving has variable loading that makes it more difficult to know when they’ll fail than the predictable environment of racing. Aluminum rods are essentially a maintenance item.
Did I miss all the rod failure threads? Seems to be a bunch of theory and speculation. I'll let you know when I break one. Later, fvcknuts!
Apparently - there are plenty out there.
Yes...theory taught to every engineer on the planet who designs every piece of machinery you've ever directly used or indirectly benefited from.
Best of luck. Hopefully they're built for an absurdly higher power mark than you're putting out.
That sucks!
Good luck with the new engine build.I don't know of anyone that beats on there engine without eventually hurting it.
Thanks for sharing and the heads up on the importance of valve spring choice and maintenance.
