- Sacreligious Swap
- Hi guys
- Blue Point Crate - Oil Pan Fitment Issue
- 67 Cutlass Supreme throttle mechanism
- 97 s10 has spark no start when moist.
- LS Swap Recommendations
- 1969 442 clone with LS3
- 49 Olds 88 4-door lq9/4l65e Ls swap
- Something waaaaay different on the dyno
- Budget friendly exhaust
- Headers = Headache
- I could really use some AC help
- 66 vista update
- Still new to this olds.
- Lsa cutlass
- LS 8 stack
- 1992 TBI 350 surging at idle (code 45)
- 355 in 68 Cutlass
- 77 drivetrain swap
- Vortec 5.7 Carb Swap (not in Olds)
- Ls swap 61 olds dynamic
- Very high idle issue - 3800 buick ln3
- Which heads for stroker ls
- 1986 diesel cutlass engine
- 383 TPI Road Race Build
- Chrysler Small Block Alumunim Manifold 4100337
- How did you learn to swap an ls engine
- Coolant reservoir relocation
- Connecting hoses 350 small block carburator
- Need help identifying name of metal hose on top of water pump; 1989 chevy corsica 2.8
- Speed Engineering Headers on GM A body with Holley forward Bias Engine Mounts
- Reliable or Easy
- Vortec heads/intake on older bottom end?
- Swap parts?
- 68 Cutlass
- Non-Olds: Anybody got a source for Hilborn style Pontiac EFI?
- A few non olds from my shop
- Oil passage for a non rotating shaft. Any engineers?
- 99 Suburban spider injector replacement
- 1965 425 swap maybe ??
- Whoe is me, the Money Pit again
- LS Swap for my ‘78 Toronado
- Full modified drivetrain swap for the 72
- Chevy 350 going into my 64 Cutlass
- Serious question about ring gap
- Big block Chevy timing
- I'm putting a chevy big block in my oldsmobile
- LS Drift
- 5.3 ls fitment questions
- Doing a engine swap from a 231 V6 Buick Engine to a 350 V8 Pontiac engine
- Jaguar inline 6
- 65 cutlass ls swap engine wiring.
- Jahns Pistons how to ID ?
- New Best
- 1991 Custom Cruiser with 305 TBI coil failure?
- Rocketman
- Camshaft advise
- 71 cutlass LX swap
- Anyone here done an LS swap in 71 cutlass?
- new cluster is a cluster f
- Small block Chevy lifter/ pushrod problem
- 72 LS swapped Delta 88
- New Corvette V8
- Vortec Headed 355
- Gen 1 Rx7 SBC swap.
- LS2/4L65e Swap
- Vibration from a bad Harmonic Balancer?
- LQ9 swap
- SBC Gen I heads/intake on Gen II block low buck conversion
- LS Oil Pans
- Saving a supercharged 3800
- 1/8 npt Temp Sensor
- Shifter Hole location for 4L60E swap
- L86 into 71 Olds Supreme convertible
- Need bell housing adapter for ls swap..1970 olds 442
- Frame mounts
- LS swapping 1971-1973 OLDS 98/88
- 1970 Cutlass LS2 4l80E swap
- NA 2.56 Gear 4275 Pounds, 11s?
- 6,2 Diesel
- Stalls out coming to a stop- Chev 250 In Line 6 Cylinder
- 91 Olds CC 305 TBI Dead on road!
- 1970 Cutlass LS Swap Fitment Issues
- Never thought - I'm going LS
- 360 Inch SBC Build
- 5.3 ls
- I'm Going To Build A Smooth Idle 427
- Can someone confirm my engine math?
- ZZ572/620 Deluxe Connect & Cruise
- My 71 Resto-Mod - a work in progress
- Went and looked at the work on the 51-98
- Help needed for 350 SB drop
- 455 Olds vs SBC motor mounts question.
- 1978 Oldsmobile cutlass salon
- 1967 CS Holiday Coupe
- Modern V8 swapping a 68 toro
- Think I'm going to quit giving advise till I get smarter
- 1956 Olds 88 Holiday Coupe LS3 Swap
- 1951 olds 98
- Chevy small block engine swap
- Pro-touring Vista Cruiser
- 6.0 LQ9/4l80e swap using Holley parts
- 65 Cutlass headers for LS engine
- Chevy Rocker Adjustment
- 1974 GMC SPRINT SP 350 for sale on CL in PA
- Possible LS swap on 1952 Deluxe 88
- Swapping out a 394
- 1955 Super 88 Diesel
- Pontiac 400 into a Cutlass?
- Town and country noise from engine area
- LS engine for frame off by beginner thread
- My project
- '49 Olds 98 Convertible LS
- 68 Cutlass S Convertible - Restomod/Protouring
- 1949 Olds 98 Ragtop
- Build my Inline 6 250ci
- Very much out of my wheel house. stumped
- Vortec 8100 swap, heater supply line options
- Accelerator cable
- 1964 Starfire carb question
- Price for LS motor and transmission
- Engine stalling
- running engine with kerosene in crankcase
- need help - 90 Cutlass Ciera
- LT1 Swap
- What's it worth?
- pink ign wire 12v cranking?
- 1962 Super 88 Swap
- 1973 Omega Restoration with Pontiac ohc6 sprint
- 402 bbc with 400 turbo tranny
- 68 Lemans 350 engine
- Mechanic wants to swap out engine for a GM crate
- Help newbie with engine
- 66 Cutlass 6.0LS
- Help. 69 442 with chevy 400 making a horrible noise
- Engine replacement blasphamy
- Turbo Ls in Winnegago
- Chevy mounts cause yoke to stick out
- L31 Vortec 350 vs Olds 350 for 1967 El Camino
- Check me on a 73 Econoline and a Holley
- O4 chevy cavalier5speed 2.2 ecotech
- Bang blow suck: non Olds
- springs too soft in front for a sbc 350
- dropping a 468 in my cutlass
- 64 cutlass radiator
- 350 Sbc in a 61 f85 wagon
- some pics 64 olds 98 vert, now 4 speed
- 6.0 4l60e finally done.
- Please Help!!!!!!!
- Valve Covers
- Barrett Jackson - Custom 1965 442
- Wiring advice
- 6.0l lq4
- Check engine light wire
- Fresh motor with new issues
- Olds 307 to Chevy 350 swap in 89 Cadillac brougham
- 2003 Chevy 5.3 water pump gasket technique
- Fresh motor issues
- Chevy in a 1974 Olds
- 403 swap to 350 chevy
- My Stock Buick 455 Build
- I may have put a hurt on my ricer Miata NA6 engine
- What should I do?
- Buick/Olds 3.1L misfire help
- LS 5.3L Into '49 Olds 98
- 1973 Olds Delta 88 Convertible - Chevy 427 tall deck?
- LS or SBC Swap into 62 Skylark.
- 1970 LS swap info needed
- Carburated I4 swap?
- NEWBIE W/ 2000 Intrigue need advice PLEASE
- 1986 engine replace with 283
- Jetstar 88 LS conversion
- 65 Cutlass Convertible to LS/4L60e + complete frame off
- 68 cutlass Ls swap??
- under drive or overdrive pulley
- LS motor swap advice
- Chevy 350 engine drop into 73 cutlass 442
- 1999 Lexus es300
- 64 grand prix
- Intercooler Location on 1965 Cutlass
- swap from 350 rocket to LS.
- 1960 98 radiator dimensions
- Truck Build
- 5.3 Truck intake in 71 Cutlass S
- Manual transmission swap
- 1981 Buick Regal carb
- Help taking a Small Block Appart
- 65 F85 Buick 455
- 62 f85
- 1964 buick 300 parts
- Rover Swap Intersting Article
- Is my diagnosis correct?.
- NEWB From Colorado
- Chevy 262
- gauge options for 68 cutlass with ECM/OBD2
- Need help with springs and ball joints
- 1963 Olds Dynamic 88
- LS swap help
- big block chevy and muncie 4 speed swap
- Anyone do a 5.3L late model engine/trans swap in 68 to 72 cutlass?
- 2jz help
- Baffled fuel tank
- 1972 cutlass Ls swap 6.0
- Buick 455
- new bie with a 1956 olds (LS swap need guidance)
- 65 230 chevy
- Go Ahead, Call Me Sacreligious
- IM building a chevy yes its happening
- Chevy 350 for 1500 on JEGS
- Mopar ignition coil gets very hot
- please help sbc swap
- Machine shop, MA/CT area
- LS swap transmission
- 64 F85 post project
- 72 cutlass with chevy 350 motor issue
- Radiator hose for 70-72 Cutlass with LS
- What Cluster Panel
- Chevy 5.3L Into '49 Convertible 98
- sbc carb woes
- Quality of backhoe's
- Forgive me forum, but I am about to sin...
- Need help with LS swap in an 83 delta
- LS in a 72 Cutlass wagon
- Sticking Valves
- '76 442 restoration. any opinions and help? what you think about the car
- Willys Go Devil L-134 optimization
- Buick 455
- 86 cutlass 442 engine swap
- 350 Ramjet in 1970 Cutlass underway
- 2000 Dodge Dakota 3.9 to 5.9 swap
- My old cheap S10 build
- dodge 440 in a 84 cutlass Calais?
- 350 with 700R4
- Ls swap question
- LS1 and TKO 500/600 in 1968 convertible
- b-body and motor mounts
- AMC QJ problems
- 'GASSYLASS' 67 sraight axle gasser Cutlass
- BBC 502 plugs
- Start of a new project...
- Pontiac 400 Engine Turbine noise Video
- SBC 350 PCV question
- ls conversion
- Hotchkiss M201 engine swap
- 86 chevy truck
- Update on 1967 Cutlass Project.
- First start!
- Summit Racing Carb I installed on my Chevy 350
- 56 olds rat with chevy small block
- How to remove this OIL PAN
