Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
97 s10 has spark no start when moist.
Old Mar 19, 2026 | 02:30 PM
Lars's Avatar
I got a 97 s10 with a 4.3 and when its get humid out it wont start. its got new cap,roter,coil and ingition moduel.
Its got fuel pressure or i can dump gas down the throtle body and wont start.
i pulled #1 wire and put a test light in and theres spark but no start. 2 other thing i was thinking was crank positioning sensor and the distributor body.
it just wont start when its moist/ humid out.
Old Mar 19, 2026 | 03:08 PM
66_Jetstar's Avatar
Did you put plug wires on it?
Old Mar 19, 2026 | 05:43 PM
Sugar Bear's Avatar
On a dry day when it will start you could spray individual components/areas with a spray bottle of water to help locate the problem area. Also could try running it at night with the hood up to look for arcing. Be careful touching components when it is running, if it is leaking secondary high voltage and you touch it you will get shocked.
Old Mar 19, 2026 | 05:54 PM
tru-blue 442's Avatar
Old School Olds
Try this forum.
https://www.s10forum.com/
Old Mar 20, 2026 | 03:01 AM
You mentioned that you replaced the module, cap and rotor. Do you still have your original module? If so, I'd go back to it. You can always have a module tested at the auto parts store.
Also, make sure you use thermal paste below the module. You can get this on Amazon.
https://www.arctic.de/us/products/co...l-pastes-pads/
Old Mar 20, 2026 | 04:13 AM
BillK's Avatar
Lars,
I don't know about the 4.3's but in those years the 5.7's are notorious for the distributor caps causing problems and AC Delco caps and rotors being the only ones to use.
Also like Sugar Bear said try misting it with a spray bottle at night. Even better if you can get someone to sit in it and power brake it to get a load on the engine.
Old Mar 20, 2026 | 05:32 AM
Lars's Avatar
the plug wires are newer replaced a few years ago. i will try other sugestions thanks guys
FN723
Jul 14, 2019 09:30 AM
youncon
Jul 31, 2012 05:23 AM
bigfun64mo
Oct 15, 2011 08:50 PM
dallasite21
Mar 4, 2010 04:51 PM
thatguy32567
Jan 7, 2009 05:05 AM
