Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
68 cutlass Ls swap??
Old September 18th, 2017, 10:47 AM
Jfoss888's Avatar
I am in the midst of my frame off full restoration build on my 68 cutlass. I'm looking for a little guidance for resale. I have a 2010 6.0 l96 motor with a 4l60e transmission that I'm contemplating on putting in it, I also have the original 350 rocket that I pulled out, which needs to be rebuilt if used. My question is will this car be worth more with the original, or with the 6.0?
Jfoss888 is offline
Old September 18th, 2017, 10:50 AM
svnt442's Avatar
If it were a 442 I would say stay with the original driveline, but being a standard Cutlass I think you have more leeway with what you want to do.
Me personally I'm a bit of a purist, but It's your car to do with as you please.
Just remember that the cleaner the install, the better chance you have of breaking even or making a profit.
svnt442 is offline
Old September 18th, 2017, 11:03 AM
Jfoss888's Avatar
It is not a 442 , I would not even consider the swap if that were the case. I'm not really building the car to keep for myself, more so to drive while waiting to sell. Do you think there will be a big enough margin between the ls and original? It will cost me about $1,500 more to put the ls in because of the wire harness, computer, pedal... etc ! I just know that a lot of guys would like to see the original, I figure with the car done it should be valued around 20-25k?!?!
Jfoss888 is offline
Old September 18th, 2017, 11:05 AM
garys 68&72's Avatar
If you're asking which will make you money, the answer is probably neither. Very few big projects make money.
A rare or desirable car (442) will always be worth more with the numbers matching motor.
Mine had no motor, trans, etc, so choice was easy.
Well done LS swaps make reliable drivers and can be worth quite a bit.
garys 68&72 is offline
Old September 18th, 2017, 11:20 AM
svnt442's Avatar
And on the plus side the 6.0L should easily make more power and get better mileage than the 350 will.
It all depends on the amount of work that you really want to put into it.
svnt442 is offline
Old September 18th, 2017, 11:30 AM
Jfoss888's Avatar
ok I appreciate the help ... thanks to both of you !
Jfoss888 is offline
Old September 18th, 2017, 12:10 PM
Just an FYI, 20-25K is going to have to be a pristine car.
Around here you can find a really nice original 68-72 Olds in the low teens.
An LS swap would have to be a nice pro-tour build with lots of upgrades to get over $20K.
Old September 18th, 2017, 12:21 PM
Jfoss888's Avatar
Without a doubt, I don't plan on just throwing the car together in hopes to sell high, I'm am going through the car 100% new floor pans, trunk pan , new quarters brand new interior, brand new wire harness throughout the car , complete four wheel disc brake conversion with drilled and slotted rotors, brand new quality paint ... all things considered I was just looking for some guidance from guys that know the Oldsmobile world a little better than me, because I know a lot of guys frown on taking the original out of the car.
Jfoss888 is offline
Old September 18th, 2017, 12:23 PM
There is an a$$ for every seat in the car business, all it takes is one person to fall in love to sell one. Do what you want with the car, as long as its tastefully done within the realm of hotrodding you should have no trouble selling it. With that said, over $20-25k cars are generally starting to compete in the muscle car territory.
oldcutlass is online now
Old September 23rd, 2017, 08:17 PM
1971 cutlasssupreme's Avatar
Worth more or less really isn't the question in my mind. I put a 6.0 in my car last year in place of a really nice 455... totally transformed the car, as in "fun factor" went sky high! You may just like it so much after the swap to decide to keep the car!!! But, as they say, build it and they will come....
1971 cutlasssupreme is offline
'69CutlassVert'
August 25th, 2011 07:19 AM
olds70supreme
August 1st, 2011 05:22 PM
<jimmy>
November 18th, 2007 02:09 PM
macarthur
January 10th, 2007 05:19 AM
skibone
April 15th, 2004 03:13 AM
Quick Reply: 68 cutlass Ls swap??
