Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Pontiac 400 Engine Turbine noise Video
Old May 24, 2015 | 06:07 AM
delta_88_germany's Avatar
Hey
I got a Strange Noise like a Turbine when Running the Engine hot.
I think some bearing issue with one pulley...
How do you suggest to identify from where it Origins.
Video
http://www.youtube.com/watch?v=O5CZiSWFIvE
Alex
Old May 24, 2015 | 06:25 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Its because the Delta is screaming for an Olds engine...lol. Check the power steering pump alternator etc...unhook all the belts and turn it on for a minute see if its still there. If it is Id look at the trans.
What have you changed recently? Ive heard distributor rotors scrapping on the cap do this too.
Old May 24, 2015 | 07:29 AM
As stated above, disconnect all the belts and see if its still there. Process of elimination.
Old May 25, 2015 | 02:48 AM
So i did it. All belts Off. Sounds still appears seems comming from the Carb inside the engine..
Distributor was changed last year
http://www.youtube.com/watch?v=8bpMbMrNAYc
Old May 26, 2015 | 07:33 AM
Definitely sounds like a vacuum leak. Hook a vacuum gauge to it see what it reads. Do the plugs read lean?
jcmoretti
Feb 8, 2015 11:03 AM
delta_88_germany
Non-Olds Engines
Sep 28, 2014 05:44 AM
Bad68442
Dec 4, 2013 08:06 PM
1968Cutlassfallbrook
Aug 4, 2011 08:45 PM
1965cutlassragtop
Jun 24, 2011 10:06 AM
