Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Knock Knock when hot 75 pontiac 400 video
Old Sep 19, 2014 | 07:35 AM
delta_88_germany's Avatar
Hey
I have a problem, when engine Is hot after 15 min driving i got a Loud knock knock Sound from the engine... Seem that something ob the valvetrain is wrong.
I checked the Rocker Arms and measured compression - everything fine!
Does anybody have an idea!??
Here is a video
Alex
Old Sep 19, 2014 | 08:23 AM
Not very good sound of the knock coming on my laptop.
Old Sep 19, 2014 | 10:17 AM
Here is a 2nd video i Made
Old Sep 19, 2014 | 10:44 AM
Is the noise coming from under the valve cover?
Old Sep 19, 2014 | 10:56 AM
Not clear but seems to comming from unnder passenger side valve cover...
I checked under the cover no rocker Arm has Play,,,
Old Sep 19, 2014 | 01:09 PM
442craig's Avatar
Is it hitting the valve cover? Any dents or scrapes on the inside?
Old Sep 19, 2014 | 01:38 PM
don71's Avatar
same but different
Yea, it sounds like a rocker arm is hitting a baffle.
I would be looking for any "witness marks" on the inside of that cover.
Old Sep 20, 2014 | 02:23 PM
hey
the arms and cover are fine. i also checked the valve adjustment all nurs are tourqued right down....
maybe can be a lifter has an issue `
Old Sep 20, 2014 | 03:52 PM
You need to try and isolate the noise before trying to replace or repair things. Did you run it with the valve cover off to see if it made noise?
Old Sep 20, 2014 | 05:16 PM
classicmuscle442's Avatar
Sounds like a lifter.
Old Sep 21, 2014 | 12:46 AM
i tried... its not comming from under the valve cover....
how can i identify a lifter?
also when driving abound with 49 mph its makes a fast not very loud tick tick tick sound ...
i also tied disconnecting each zylinder but does not affect ehe sound in idle ...
Old Sep 21, 2014 | 12:51 AM
Oldsmaniac's Avatar
It sounds external to me, hard to say....
Old Sep 21, 2014 | 03:31 AM
i am sure that this is from the engine not from the accessory
i checked under the cover and every rocker arms looks moving correct...
if you are refering to the sound it seems that the knock is komming every 8 th turn... so its comming 1,5 times a second...
which pinthe to be a lifter
my other thought is that it could be a bearing issue like this guy in the video has... but his knock is way mor often then mine ...
so may i should replace all lifters ....
if the sound still appear is must be a crankshaft - rod bearing issue...
Old Sep 28, 2014 | 05:44 AM
so the weekend is over and the engin is running smooth :-)
i replacend the lifters and rocker am studts to go to a adjustable vlave train..
the engine makes no chattering or ticking sounds, more quiet then ever :-)
used this instruction to set valve lash
http://www.boyleworks.com/ta400/psp/rockers.html
thanks
delta_88_germany
Non-Olds Engines
May 26, 2015 07:33 AM
BangScreech4-4-2
Feb 25, 2015 11:18 AM
delta_88_germany
Brakes/Hydraulic Systems
Nov 2, 2013 05:06 AM
805cut
May 25, 2012 03:30 PM
walkthwalk92
Jul 21, 2009 08:30 AM
