Chevy 350 going into my 64 Cutlass
I wanted very much to keep her as stock as possible. However, reality dictates the swap. I simply haven't the resources or the time to rebuild the original 330. So, I have a nice running Chevy 350 to drop in. I am wondering, in advance of the swap, what headers, if any are available for it. Also, I don't think the stock motor mounts will work with the new engine. I won't know until I have the 330 out. Am I correct, or am I goofy?
I already have the proper adapter plate to keep my automatic transmission. Earlier, I had to replace the original two speed with a late 70's Pontiac TH350.
Typically frame mounts, motor mounts, & headers from a same year Chevelle/Malibu should be what you are looking for.
Since you have the trans adapter, the only other hurdle is relocating starter wiring to the passenger side.
