chevy 350 swap to olds350
Old Jun 17, 2015 | 07:41 PM
apage1's Avatar
I have a 70 chevy pickup with a bad chevy 350 engine. I have an 70 olds 350 engine I want to install. Will the engine be a direct replacement with minor changes? Will chevy 350 headers fit? Will I need to get new motor mounts? Not sure what to expect. Any feedback would be appreciated
Old Jun 17, 2015 | 07:53 PM
Welcome to the site.
You need Olds frame brackets and motor mounts. The headers will not work and you'll need an adaptor for the transmission or a BOP style transmission. Some wiring changes, etc...
Old Jun 17, 2015 | 07:54 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You will need Olds headers, mounts and a bop trans or adapter plate. I have done a 78 2wd 1/2 ton and my current 94 4x4 . The Olds 350 is a much better truck motor than any SBC.
Old Jun 17, 2015 | 07:58 PM
Yes, wires need lengthened since sensors are in different places.
Old Jun 17, 2015 | 08:02 PM
apage1's Avatar
Thanks guys, I have the trans with the engine, I will investigate motor mounts and placement onto the frame. It looks like the trans is the same length as the chevy and will fit nicely. It appears at first glance I might need to only replace the flowmaster headers I currently have.
Old Jun 18, 2015 | 06:37 AM
It should be pretty easy then, good luck. If its a SWB, save your old parts as you may want to go back in the future.
Old Jun 18, 2015 | 12:31 PM
The Olds motor was factory installed in the 1973-1987 family of Chevy trucks in the form of the 350 diesel. The mounts for THAT application make it a bolt-in for THAT family of truck. No such mounts exist for the 1972-earlier Chevy trucks. You'll need to fabricate or adapt everything. The Olds 350 and Chevy 350 are completely different designs with NOTHING in common, not even the bellhousing bolt pattern.
Old Jun 18, 2015 | 01:00 PM
I thought the frame brackets were the same or can be modded easily.
Old Jun 18, 2015 | 01:03 PM
The frame brackets for a Chevy aren't even close to those for an Olds. Anything can be modded with a torch.
Old Jun 18, 2015 | 04:18 PM
M-14's Avatar
Isn't there a set of engine brackets the fit the olds that allow you to use sbc mounts? I think they were from 403 firebirds.
Old Jun 18, 2015 | 04:25 PM
70vert's Avatar
Yes but that early of a Chevy truck does not use the clam shell mounts. It's uses the old style mount with the rubber on the motor that rip apart.
Old Jun 18, 2015 | 06:32 PM
Weld the frame mounts or drill out to match. I welded mine on my 78 and used Firebird mounts on the 94.
Jolds86
Dec 16, 2014 07:49 AM
65442ragtop
May 21, 2014 10:59 PM
oldsmob71
Non-Olds Engines
Jan 5, 2014 01:22 PM
olds425
Nov 18, 2010 11:23 AM
wdm3000
Jan 22, 2008 12:12 PM
