Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Chevy 350 going into my 64 Cutlass
Old Sep 4, 2023 | 05:15 PM
Bobbity's Avatar
I wanted very much to keep her as stock as possible. However, reality dictates the swap. I simply haven't the resources or the time to rebuild the original 330. So, I have a nice running Chevy 350 to drop in. I am wondering, in advance of the swap, what headers, if any are available for it. Also, I don't think the stock motor mounts will work with the new engine. I won't know until I have the 330 out. Am I correct, or am I goofy?
I already have the proper adapter plate to keep my automatic transmission. Earlier, I had to replace the original two speed with a late 70's Pontiac TH350.
Old Sep 5, 2023 | 07:31 AM
Lonnies Performance's Avatar
Typically frame mounts, motor mounts, & headers from a same year Chevelle/Malibu should be what you are looking for.
Since you have the trans adapter, the only other hurdle is relocating starter wiring to the passenger side.
Old Sep 5, 2023 | 09:02 AM
As stated above, just treat the car like a same year Chevelle. Engine frame brackets and engine mounts, minor wiring changes, etc... will be required.
Toocool
Jul 15, 2018 08:27 PM
apage1
Jun 18, 2015 06:32 PM
88jetstar
Aug 15, 2014 10:46 PM
ajschirling
Oct 7, 2012 04:33 PM
Wasted
Aug 25, 2011 09:44 AM
