Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Buick 455
Old Jul 14, 2016 | 03:36 PM
Fletchmo72's Avatar
Buick 455
Wondering how a '70 Buick 455 compares with an Olds of the same year. And whether I could drop that Buick 455 into my '72 Cutlass Supreme, which currently has an original 350 motor and 350 trans.
Jack
Old Jul 14, 2016 | 04:09 PM
The Buick is comprable to the Olds, but is different. As your car is an A body, you would have to treat it like a Skylark or GS and use the frame brackets and engine mounts for a Buick. It is basically a bolt in with minor wiring and exhaust changes (you need to use the Buick exhaust manifolds). Your transmission should bolt up, but I think you'll need the Buick torque convertor.
Old Jul 14, 2016 | 04:32 PM
svnt442's Avatar
Torque converter is the same.
Old Jul 14, 2016 | 05:18 PM
Thanks for the clarification, wasn't sure the bolt pattern was the same to the flex plate.
Old Jul 14, 2016 | 06:23 PM
CRUZN 66's Avatar
Olds Fever
Buick starter location is opposite the 455 Olds... Left side for Olds & right for Buick...
Old Jul 14, 2016 | 06:45 PM
Falls under minor wiring changes. Just as the distributor is in the front of the engine.
I did forget the fuel pump is on the opposite side though.
Old Jul 14, 2016 | 08:14 PM
Fletchmo72's Avatar
Thanks, All, for that info on the Buick 455. I saw some posts elsewhere comparing the Pontiac, Buick, and Olds versions of the 455. The Olds was (gasp) considered the least desirable due to a "longer stroke" and other technical issues. I don't know if they know what they're talking about. But does anyone have thoughts on the merits or considerations of using a non-Olds motor?
Old Jul 15, 2016 | 05:36 AM
I don't understand your question on "thoughts on the merits" part?
Old Jul 15, 2016 | 08:58 AM
CRUZN 66's Avatar
Olds Fever
Well then, let's also not forget the minor relocation of the battery tray to do the task correctly...
Old Jul 15, 2016 | 09:23 AM
That's not a necessity, the cable and purple wire can be extended to route to the starter along the firewall and drop down behind the right side head.
Old Jul 15, 2016 | 09:56 AM
Octania's Avatar
Crossed starter wires, crossed fuel lines....
Might need a donor GS car.
if the Dist'r is at the front, how is the oil pump driven and where is the sump? I have seen ford motors with a fwd sump.
Old Jul 15, 2016 | 10:15 AM
Fletchmo72's Avatar
Thanks again. I found a '70 Buick wagon with a 455/4 barrel, in great shape with very low miles. I like the car on its own merits. But also thought I might swap motors someday: My 350 into the wagon, 455 into my '72 Cutlass.
Old Jul 15, 2016 | 12:50 PM
Seems like a lot of work...
Old Jul 18, 2016 | 07:27 AM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
oil pump driven the same way, on the other side of the dizzy via a driveshaft...and sump is handled by the pickup tube which will be correct for the donor motor.
as for desirability, I would rank buick the last and pontiac first - simply because the aftermarket was kinder to pontiac 455's
unless you found a gs stage car, the 455 is designed to never see much above 3500 rpm and pull around a 5500lb car....for hp numbers from buick, I liked the 430 better....
Old Jul 18, 2016 | 07:28 AM
quaddriver's Avatar
4 Barrels of Laughs
great demo derby car...but if the body is mostly rust free, a great restore project....
ralsy
Jun 30, 2012 04:22 PM
Jayycobb
Drivetrain/Differentials
Dec 6, 2011 07:27 AM
toreson2000
Oct 20, 2008 08:30 AM
regalrocket
Apr 20, 2007 01:27 PM
mikkim129
May 10, 2006 07:06 PM
