Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
LS in a 72 Cutlass wagon
Old Nov 28, 2015 | 02:49 PM
rktolds's Avatar
Everything is pretty straight forward but I'm wondering about the gas tank. The A body tank has been done but can't find info on the wagons.
Old Nov 28, 2015 | 05:06 PM
jozw30's Avatar
Talk to Ricks or Rock Valley.
Have seen guys use them for LS wagon swaps. Not cheap, but they'll get you there.
Start a build thread with lots of pictures!
Old Nov 29, 2015 | 06:17 AM
rktolds's Avatar
Thanks. Looks like aero motive makes an in tank pump and pick up with extension for a deep tank. Still $600-700 to go that route. Wow.
Old Nov 29, 2015 | 07:29 AM
gearheads78's Avatar
car guy
Cheapest way is find used tank setup that works with a metal tank before they all went to plastic tanks. Look at trucks early 4gen f-body ect. Cut the top of the tank out and fabricate / weld to the top of your tank.
Old Nov 29, 2015 | 07:42 AM
garys 68&72's Avatar
Is the wagon tank a tall one mounted in the rear quarter?
You may be able to use a stock GM pump if the wagon is the correct depth and there's a flat spot on the top to mount it. Vetteworks makes a mounting ring and sells the f body pump assembly, no regulator required too.
http://vetteworksonline.net/
And a variable height option, reasonably priced too.
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
Old Nov 29, 2015 | 11:02 AM
car guy
both are good options
Old Nov 29, 2015 | 12:28 PM
rktolds's Avatar
LOVE this website. You guys rock. If this hurdle can be overcome without costing an arm and a leg then I may need to go ahead and do the swap. Fuel injected family hauler is sounding sweet. Just time consuming saving for all the parts. Thanks for the help.
Matt
Old Dec 3, 2015 | 06:33 AM
rktolds's Avatar
I wanted to update this just in case others can use the info. It will be awhile before I decide exactly what I want to do. I may do a 455 with EFI or just get it going with a factory correct 455 or an LS swap. Anyway I found this: http://www.jefflilly.com/gallery/hot...-tank-mod.html
Not sure what model of Camaro they used for fuel pick up and pump.
Old Dec 3, 2015 | 06:48 AM
jozw30's Avatar
If you decide to go LS, get on LS1tech.com.
Several 68-72 A-body wagon build threads on there.....
Good luck!
Old Dec 3, 2015 | 07:47 AM
If the tank is tall and narrow, you could use an external pump with the original pickup.
I'm running that setup on my 68 vette with no starvation issues even below 1/4 tank.
The flat wide tank in my 72 Olds is a different matter. Definitely need a sump there.
Old Dec 3, 2015 | 12:43 PM
rktolds's Avatar
Gary,
That gives me another option. Thanks. I would have thought the tall tank would make it hard to "pull" fuel from the tank.
I will check out the ls1 website. Thanks.
Old Dec 3, 2015 | 01:42 PM
It's an issue if you mount the pump high, you need to mount the pump below and as close to the tank as possible. Then it's just a siphoning effect. You'll still need a regulator and return line.
I will say I prefer intank pumps since the fuel cools them.
scot w.
Aug 18, 2009 09:03 AM
Pghstarsky
Jul 24, 2008 07:15 PM
taps442
Jun 30, 2008 08:24 AM
Omicron
Apr 27, 2008 11:20 PM
scot w.
Sep 4, 2006 07:50 PM
