Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Help needed for 350 SB drop
Old Dec 18, 2020 | 11:02 PM
Bakewoods14's Avatar
I have a 1984 Cutlass supreme and I want to drop a 350 SB in it. Money isn’t an issue I just need to know exactly everything I need to perfectly do this the best way possible. From wiring harnesses to the motor mounts to how the starter should be set, any help is appreciated thanks!
Old Dec 19, 2020 | 07:21 AM
RetroRanger's Avatar
72 Olds CS
Some more info might be helpful. Are you taking out a 6 cylinder? Are you putting in a chevy sb or olds sb? Are you replacing the trans too?
Old Dec 19, 2020 | 07:51 AM
HighwayStar 442's Avatar
Hi, welcome to the site. I have a 1987 cutlass.that had a V8 307. The 350 fits right in. Did not use any of the computer. Just get a good running 1968 to 1972 SBO. If you rebuild the engine for more power, upgrade to at least an GM 10-bolt 8.5-inch. And add body stiffeners. High powered V8 will twist the frame and body. Save the accessory brackets from both engines if V8
Old Dec 19, 2020 | 09:34 AM
Yeah im took out the V6 putting in a chevy sb
Old Dec 19, 2020 | 09:42 AM
I think that the wrong direction. But to each his own..
Old Dec 19, 2020 | 12:24 PM
Wrong direction ?
Old Dec 19, 2020 | 01:43 PM
Bfg's Avatar
Bfg
You need to invest in a compass!
Old Dec 19, 2020 | 02:01 PM
Wrong direction ?
Sorry! Most on here want to keep our cars all oldsmobile. Olds 350 would just a bolt-in, pretty much. Not sure about the transmission. I would not think it would hold up to any 350. I think yours is a Buick V6 and a three speed transmission. I know little about them.
Old Dec 19, 2020 | 03:31 PM
As said above, an Olds engine is an almost drop-in replacement for a Buick engine. Installing a Chevrolet engine involves a lot more work.
Old Dec 19, 2020 | 06:07 PM
I understand it’s going to require more work but I want to know exactly what that work is gonna be. I mean no disrespect to the community, it’s on this thread for a reason.
Old Dec 19, 2020 | 06:17 PM
72 Olds CS
I dont know everything involved in swap olds to chevy but items like distributors starters manifolds transmissions accesories etc wont swap. So you will need all that stuff plus the engine.
Old Dec 19, 2020 | 09:34 PM
You need to treat it like a Monte Carlo and get the Chevy engine mount frame brackets that bolt to the cross member. You'll need a transmission that has the Chevy bell housing bolt pattern. The rest is fairly straight straight forward, starter wiring needs to be moved, new fuel line from the pump, sender wires moved around, hoses, etc... Depending on transmission used you may need a drive shaft and some e-brake cables.
Old Dec 20, 2020 | 06:07 AM
edzolz's Avatar
All of the above plus about 30 extra hours of labor to relieve all of the heartache from sorting out the problems that will crop up.
Old Dec 23, 2020 | 07:48 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The trans is either a TH200C or TH250C, if stock and both weak. A Buick 350 is a completely direct swap, everything swaps over. Either a sbc or Olds 350 will need accessory brackets and frame mounts, along with wiring changes to work. The Olds 350 is a great motor. I bought my 88 because it was factory Olds 307 powered, super easy to swap in other Olds V8's, very rare in Canada.
jtriggy
Non-Olds Engines
43
Sep 21, 2017 12:53 PM
MrTorresJr
Non-Olds Engines
Sep 18, 2014 03:47 PM
oldsmob71
Non-Olds Engines
Jan 5, 2014 01:22 PM
xplicit666
May 21, 2009 05:54 PM
<jackiehppy4@aol.com>
Mar 26, 2004 06:52 PM
