LS swap transmission
Hey guys,
I am considering doing an LS swap on my 64 Cutlass. It currently has a TH350 in it that can't hold fluid. Is there a cheap manual transmission that would be worth using? The ones coming out of newer Camaros and Corvettes all seem to be $1500+. Are the gear ratios in a truck transmission unusable in a muscle car?
Thanks,
-Mike
Thanks,
-Mike
You can run a Muncie or T10. They can be found for a few hundred and will require a $100 rebuild kit.
As for OD trans, the T5 is probably cheapest, but not very strong. And the easiest would be from a V8 3rd gen F body, but those are pretty old and most in bad shape.
The truck trans generally have a really deep 1st gear, some in the 4-6:1 range.
What's your current rear end ratio and what do you plan on doing with the car?
If you have a 3.08 or higher rear look for a wide ratio Muncie or super T10. They have around a 2.6 1st gear. Probably not worth the added expense of OD to save a few bucks on gas.
Also, most of these older cars require tunnel cutting for a T56.
Are you looking at an aluminum block or a 5.3/6.0 truck iron block?
Is there a way to tell which gears I have besides taking the rear end apart?
e rear tires off the ground, rotate the driveshaft till the wheels make 1 revolution.
You should be able to count the number of driveshaft turns. Just over 3 =3.08
There's also a code on the right front of the axle (I think). Google axle codes for ratio.
Thanks, I'll check that out.
Figure out your rear end ratio. Then pick a trans to fit.
3.08+ you can use a wide ratio Muncie/T10 (2.6 1st gear). Under that, you can use corvette super T10 (2.88 1st) or a Camaro T10 (3.42 1st).
And everything you need to know about hooking a Muncie/T10 to an LS motor:
http://ls1tech.com/forums/conversion...-ls-motor.html
