1964 Olds Dynamic 88 Engine Swap - Transmission
Old Jan 21, 2008 | 10:30 AM
bccsrc's Avatar
Question 1964 Olds Dynamic 88 Engine Swap - Transmission
Hello,
I have a 1964 Oldsmobile Dynamic 88 394 with a 1959 Hydra-matic transmission. It has slipped in second gear for a long time. I would like to see what it would take to swap out the engine and transmission for a later model transmission and a 455 Oldsmobile.
What type or engine mounts and transmission mounts will I need? I would like to still run the Dual Carbs and have dual exhaust.
Could the Linkage cause the transmission to slip in second gear? Can I unhook the kickdown linkage to see if it would shift correctly? My dad always thought it was the smaller torque converter which controls 2nd gear. He isn't here anymore so I can't ask him.
What do you think?
Old Jan 21, 2008 | 02:35 PM
Oldsguy's Avatar
Past Administrator
contact olds64, he has done some research on that subject.
Old Jan 22, 2008 | 11:20 AM
88 coupe's Avatar
Junior Member
Originally Posted by bccsrc
........ what it would take to swap out the engine and transmission ........
https://classicoldsmobile.com/forums...94-1962-a.html
Norm
Old Jan 23, 2008 | 03:54 PM
I just sent you a PM.
Old Feb 3, 2012 | 01:59 PM
Dean Eechaute's Avatar
I am looking to install a 425 with a 400 tranny in my 64 88 convertible. Any insight on how you did it would be a great help. I have the engine mocked up roughly where it needs to be and debating on wether to use a custom cross member or make custom mounts using a 65-67 engine mounts. Dean
Old Feb 5, 2012 | 11:02 AM
Dean,
We all appreciate that you're looking for info and we're happy to provide it, but posting the same question on a bunch of four and five year old threads is probably not the best way to get info. I suspect that you'll avoid confusing responses if you stick to one thread for your topic. If you do find a old thread with info that you're interested in, feel free to send a PM to the author asking for more info. Most folks here will be happy to respond.
Old Feb 5, 2012 | 08:22 PM
I am sure there are many ways of making this combo work. I am just exploring all possibilities to see what others have done in this situation. Nothing personal. As always I appreciate you expertize. Dean
Old Feb 6, 2012 | 07:05 AM
No criticism intended, I'm simply suggesting that resurrecting a four year old thread is not the best way to get a useful response.
Dean Eechaute
74
Feb 21, 2014 02:18 AM
Pohlcat
Hurst/Olds
Apr 22, 2012 04:15 PM
oldsmobum
Jan 14, 2011 10:10 PM
64starfireme
Jun 24, 2009 03:04 PM
1980oldscuttnewbie
Apr 30, 2007 05:22 AM
