Transmission Swap in a 1967 Cutlass Questions
So I just pulled a turbo 350 from a 71 Skylark 4-door and I want to install it in my 67 Cutlass Holiday with a 330 and a jetaway 2 speed, So I have a lot of questions for everyone, and maybe this will help everyone in the future? Some of my questions are.....
1. Does the crossmember have to be moved back?
2. Can I use the same Driveshaft?
3. Do the transmission lines mount the same and are they the right length?
4. Do I use my jetaway tailshaft? or the one off of the parts car?
5. What wire do you use, or where do i get the wire for the t-350?
6. There is the vacuum line,is there one on the jetaway that is the same?
7. Does the Torque Coverter bolt up the same?
8. Do I need a different flex plate?
9. How do I mount the kickdown cable to my gas pedal? My pedal rests on two ***** that are mounted to the floor, on the parts car the pedal is mounted to the firewall, So help there, what to do etc, etc...
10. Anything else that would make this swap go more smoothly!
I think that if the questions were answered I think it would help me alot and a lot of other people in the future to, I know it's a lot of questions but if everyone could help it would be awesome! Thanks!
Todd
Todd
Todd
Todd
http://www.transmissioncenter.net/sp...n_______va.htm
Ok so it looks like my only problem is going to be the kickdown, The way I saw was the cable attached to the foot pedal, is there another cable for the carb?, I can't use what is there now and just somehow hook up the cable to the foot pedal? Can I just take the setup off the donor car? And is there someone who makes a bracket?
TH350 kickdown cables in early '70s Olds hooked to the gas pedal not the carb. If its the same in Buicks you may just have to put a hole in the firewall. Page 7-228 of 1970 Chassis service manual.
The late-70s cars ran the cable to the throttle arm on the carb, not to the accelerator pedal.
Quick question-coming from a Buick,does the trans have the Buick bolt pattern,or is it the universal bolt pattern? I seem to remember I had a problem with this in one of my Olds's years ago. But maybe it was with a 400.
---bil
---bil
(The older Buick "nailhead" V8s)(364/401/425) had a curved pattern.
In the years 1964 til not sure when GM have 3 different bellhousing. Chev with 5 mounting holes, BOP with 6 mounting holes and a universal with 7 mounting holes. Any universals I've had. have come from early '70s Olds.
Big Todd, when you do complete the swap, what you will notice the most is that you will have better acceleration in first gear. You are going from a 1.82 first gear to a 2.52. The 300s first gear is closer to starting out in second gear with a TH 350 (1.52). The highway rpms will be about the same with a stock convertor. And your 2 speed selector should be able to access 1st gear, but if not, you can get an adjustable arm from shiftworks. (www.shiftworks.com) (I used one of these on my 2004r in my 66 Tempest SW and it works great) (I had originally gone from a ST300 to a TH400 in this same car and was able to pull it all the way to low with the 2 speed column shifter). Good luck, and let us know how it performs.
I'm seriously looking forward to it, I just don't know what to do about the kickdown yet, I'm hoping someone has done it before and will be like, hey it's easy just buy this ........... lol
Like it or not, there were far more Chevys built than Buick, Olds, Pontiac, and Caddy, combined.
Well I know on my kids 71 Skylark Chassis Manual which is what I got the tranny from and it has a drawing of the tranny lines coming out with a in and out flow pattern, would it matter if they were backwards then?
Big Mikey
Mar 27, 2013 06:51 AM
