Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Sacreligious Swap
Old May 26, 2026 | 02:35 PM
Oldsshagginwagon's Avatar
Sacreligious Swap
hello I’m currently performing a sacreligious swap on my 59 fiesta wagon. I’m swapping an ls drivetrain and was wondering if anyone knew of any easy swap parts that fit a factory fuel tank to convert it to fuel injection. I.e. a sending unit or fuel pump that will fit in the factory tank and allow me to run new lines. Any info is greatly appreciated.
Old May 26, 2026 | 03:32 PM
JohnnyBs68S's Avatar
You might check with Holley's line of in-tank EFI pumps and sender units that might fit your factory tank. You might have to run a return line, but that is probably simple compared to finding a new tank for your classic wagon.
Any deets you are willing to share on your swap to help hone in on a more optimum solution for you? This post reeks of a LS swap, not that that it is entirely bad (and understandable).
Old May 26, 2026 | 04:17 PM
Don't forget to check out Summit Racing and Jegs. I think there are off-the-shelf parts that do exactly what you need.
Old May 26, 2026 | 11:59 PM
cfair's Avatar
No need for apologies on the LS swap. Eminently practical solution in 2026. It will be great for us to learn from your experiences too.
I’m a carb guy, but from what little I know, if you’re going to go EFI, you’ll need to run a return line.
Guessing the fuel tank will be a thoroughly custom job. In ‘59, fuel injection was for Messerschmitt fighters and Corvettes.
Good luck!
Chris
Old Yesterday | 06:00 AM
VC455's Avatar
Barely Registered
My fuel tank is vertical, so there are no electric pumps that will fit this configuration. I believe your tank is horizontal, so it is possible to adapt something.
But you asked for an easy way. That's not it.
I bought a small reservoir tank (RobbMC PS550) that mounted behind the right headlights. The car's mechanical fuel pump fills it. It contains a standard, submerged electric pump. From there I put in a bypass regulator and a return line to the tank.
This would be an easy way to get the 60 psi or so that you need.
Nice project. Keep us informed.
Old Yesterday | 11:05 PM
cfair's Avatar
Gary,
Many thanks for the idea on the reservoir tank in the engine compartment. I’m a qjet guy so it’s irrelevant to me, but friend to hear about the modification/adaptation.
Do you run your car with such a reservoir tank today? Has it worked well/safely/long?
Just curious
Chris
Old Today | 07:57 AM
VC455's Avatar
Barely Registered
Chris, it's been everything the ad copy promised. No problems have come up. RobbMc is an upstanding supplier!
kevdog442
Nov 1, 2023 06:55 PM
wundermutt3
May 2, 2022 01:38 PM
Ttnc
Mar 28, 2021 06:16 AM
oldsvista_65
Mar 15, 2017 10:45 AM
rkk69olds
Apr 28, 2016 06:19 PM
