View Full Version : Non-Olds Engines
- Where to get engine stand bolts? (M12-1.25)
- 05 3800 intake gaskets
- Good yrs 454 chev
- Sick of LS engine swaps!
- ID this boat motor GM
- 72 Cutlass-Protouring Style
- What do I need to pull with jy LQ4?
- New member
- 1954 Olds 98 4door sedan, SBC350/th700r4
- 3.1 crank sensor location
- Intake manifold
- Need help getting the vacuum system fixed so the thermal choke will work, SBC 350
- Engine spray paint
- need help with dd/beater. 75 vw dasher
- New member!
- LS cutlass
- Horsepower guess
- '64 cutlass engine swap
- thinking of putting a diesel in a fullsize olds
- Water Pump Noise Question
- Knock Knock when hot 75 pontiac 400 video
- 72 cs ls1 or 350?
- 1981 cutlass diesel
- Any LS3 "Oldsmobile" engine covers?
- Couldn't pass this Pontiac G8 up.
- Engine/Trans Replacement
- 289 ford timing
- Help please
- 454 help
- 66 Pontiac tri power
- Looking for info on 350/350 swap into 61 olds 88
- Horn wiring diagram 55 Dodge??
- freshin top end
- Towing
- LS No Start
- 63 starfire chev motor install help
- 1928 Plymouth Model Q Coupe
- 1994 Corvette project
- Looking at 69 Impala on Saturday - Help my friend out, please
- Cheap British V8, new Aston Martin 4.3L
- Im looking for a engine
- LS1 swap in a fullsize olds
- 454 swap wiring harnes????
- 1978 Delta 88 Build
- 68 442 starter to ignition wiring
- 68 442 with a 454 swap
- Gas Tank Venting
- need pictures of m/c relocate
- Help ID Pontiac Rad/Trans Lines
- LS swap
- chevy 350 swap
- 383 Stroker in 63 F85
- 1965 Chevelle brake system query
- Top Gear "Electric" episode
- Hello. 1967 cutlass convertible
- 93 Buick 4L60E issue
- my 56 rat rod ....
- Budget estimate to convert to LS power
- Ls swap problems in 65 f85/cutlass/holiday
- Help with LS swap in 65 f85/cutlass/holiday
- 72 Vista Cruiser
- '69 Buick 430 heads
- Engine Swap help
- Buick GS question
- 64 f85
- New shoes for the 69 Camaro
- Pro Touring '72 now going LS2
- cadillac deville problems
- Next project, 1939 Packard
- 1961 super 88 powered by ford 6.0 diesel project
- G-Body/SBC combo Headers Deal
- 93 Saturn rod knock
- Does anyone know anything about Ford teapot carburetors?
- Virgina!!!! (HELP) - Chevy truck rear end replacement cost?
- 1954 Ford ignition question
- My distraction over the last two weeks 1964 Galaxie
- Here Are Some On-Line GM Truck Manuals
- 4l60e help
- Temporary wheels for the 69' Camaro
- What's wrong with this picture?
- Annoying lifter tick in an 85 305
- 71 skylark engine into 84 lesabre?
- 454 in a 70 Vista Cruiser
- need some help with a 460
- 6l90e
- gas monkey / fast n loud show
- SnakeBit and Son's 67 Cutlass 4 dr build
- questionbout 88 camaro
- '72 Cutlass LS2/6L80E build
- Chevy 350 build help
- Looking for oil pump for 68 buick electra 225 with 430
- Pics of Dad's T-Bird!
- Pics Of My Buddy's '70 Javelin!
- poncho 406
- Last resort before I drop in Chevy power.
- mustang ii front end question
- Adding power windows
- dream engine swap!
- 75 delta 88 engine swap
- Weekly builds with dyno sheets 496
- exhaust system!
- Why rebuild an Olds small block....
- Harold Bettes at work/Zora Duntov interview
- harley for classic? what to do!?
- My 68 Charger Desk
- 500 inch oval port dyno test
- 427 in a cutty
- LS Motor Conversion into A Body Cutlass
- 5.85 @ 115.15 @ 3380, 1.278 60 foot
- Dirve shaft upgrade needed, and new transmission.
- Column Shifter Linkage (73/74 Omega)
- What year is the Chevy?
- sputter in motor
- Project CutLS
- 393 powered H/O
- Ez EFI conversion
- Cutlass build update
- Best way to remove headers with engine in the way
- Header question for 1979 Cutlass with SBC
- crate engine
- Will SBC and tranny clear all at once with crossmember?
- Edelbrock carb on a 78 Vette L82
- 6 qt oild pan on a SBC in a G-body Cutlass
- My 388 stroker for my 1979 Cutlass
- Caddy 472 in 67 Olds Cutlass ?
- EFI Converion Fuel Tank
- Chevy Sport Van not starting
- clunking posi. Bad or binding spider gears??
- Stroker running
- LSx into a '64 B-body?
- Vortech 5300 ls swap in a 65 cutlass
- 572 in Olds
- need some help
- 383 combo
- 83 Suburban using 100LL
- trouble mounts.
- 84 Cutlass v6 to v8
- JOZW30's 55 88 LS2 build
- Hello Olds Forum
- any of you olds guys know much about jeeps?
- Anyone drive an EcoBoost yet?
- LS2 in a 1955 98
- Unknown Air cleaner- Calling all experts
- Muncie M62/M64
- 3.8 buick problem.
- 383 engine
- New toy for 2012
- Uh Oh, Powerblock is dong an LS Olds
- motor mounts
- Non-Olds Powered WHOOPS!
- 101 year old driving an 81 year old car
- vortec 5700 & trans into 78 cutlass w/260
- Fiat oil changing
- 327???
- Anyone Good with 6.2 Diesels?
- dodge 47re trans ?
- Need air cleaner suggestions
- Fairly hard-core, but STILL making the swap
- Well, I did power it with a GM drivetrain!!
- A discussion about what I did!! BBC And why.
- 1964 and 1966 oldsmobile questions...
- Newbie..Chevy conversion story and dumbest thing I have ever done with a car
- Engine mounts/frame pads
- 1005 sbc
- 84 h/o sbc 400 swap?
- 69 Cutlass Resto-Mod Build
- Deleted Signature photos
- Are you a mechanic?
- Chevy lover get's reprimand
- Would LSx swap in 66 Full Size require cutting?
- LS powered cars welcome!
- bobcat repair
- Like lost puppies they just follow me home...Non Olds
- new toy
- buick 455 in a delta 88
- LS swap
- Replacing the rocket with a LS series engine
- 1970 Olds 442 clone gets Gen IV 6.0L & 6 speed transmission
- 1980 cutlass/chevy 350
- Vacuum Diagram
- Speedometer Help electronic & mechanical
- questions on a TPI engine swap should I???
- Engine swap
- LSX Engine swap info , parts, options, etc.
- So can we have a legitimate LS discussion??/
- Motor change
- Anyone know this Pontiac Warning? (picture)
- 1970 Chevelle Twin Turbo LS.....super sleeper
- How much you think it is worth?
- 383 motor
- Mabee not the place
- 350 GM crate in 78 cutlass
- SBC BBC LS1 engine swaps ect
- It's not an Olds, but it can sure fly
- what do you olds guys thnk about LS motor swaps??
- Pontiac 455..Will it fit 71 cutlass????
- Non-Olds Question: Nissan starting trouble
- Swapping 72 Chevrolet 350 into 4 door 82 Delta 88 with 307
- Help identifying non-Olds part
- What non Olds builds do have going on.
- Custom 61 Olds Super 88 build up
- 72 Cutlass 454 GM BB
- 1964 Cutlass F85 with Chevy 350 Engine
