need some help
Im guessing if a chevy engine was installed correctly in the same position as a chevy engine should be in an A body gm car you should be able to fit anything that fits a chevelle since its the same frame .
I got the right oil pan but when we installed the motor the frame mounts did not line up with the motor mounts and the oil pan also hits the front crossmember there was already a Chevy 350 motor in the car.the the 350 motor has a 5qt pan and the 7qt pan on the 383.do u think I should change the frame mounts?
Yes
Thanks I'am stoked about the motor a buddy of mine is doing a ls swap on his 70 chevelle so he gave me his fame mounts so we are going install the motor over the weekend I hope everything works out
Here is a pic of my 383 stroker in the 65 cutlass. I believe I have a 6 qt pan-fit like a glove.April 15 2012 032.JPG
