Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
need some help
Old Apr 13, 2012 | 09:47 PM
gabe442's Avatar
need some help
I have a 70. Cutlass with a 383 Chevy motor now the engine that Iam installing needs a passenger side oil pan I would like a 7 qt pan does anybody know what pan would fit
Old Apr 13, 2012 | 09:52 PM
coppercutlass's Avatar
Chevy budget Olds powered
Im guessing if a chevy engine was installed correctly in the same position as a chevy engine should be in an A body gm car you should be able to fit anything that fits a chevelle since its the same frame .
Old Apr 13, 2012 | 10:24 PM
gabe442's Avatar
The Chevy 350 engine that was in the car dipstick was on driver side the new motor has a. Passenger side tube.
Old Apr 14, 2012 | 06:23 AM
Look up an oil pan that meets your criteria and treat it like a Chevelle with a small block.
Old Apr 15, 2012 | 08:06 AM
gabe442's Avatar
I got the right oil pan but when we installed the motor the frame mounts did not line up with the motor mounts and the oil pan also hits the front crossmember there was already a Chevy 350 motor in the car.the the 350 motor has a 5qt pan and the 7qt pan on the 383.do u think I should change the frame mounts?
Old Apr 15, 2012 | 08:23 AM
Seriousfun's Avatar
*ssholes Garage
Yes
Old Apr 16, 2012 | 09:13 PM
gabe442's Avatar
my 383
this is it
Old Apr 17, 2012 | 04:21 AM
Seriousfun's Avatar
*ssholes Garage
That looks very nice.
Old Apr 17, 2012 | 05:32 AM
gabe442's Avatar
Thanks I'am stoked about the motor a buddy of mine is doing a ls swap on his 70 chevelle so he gave me his fame mounts so we are going install the motor over the weekend I hope everything works out
Old Apr 17, 2012 | 02:18 PM
oldsguybry's Avatar
NOVICE car nut
wow , that things a beast
Old Apr 17, 2012 | 08:19 PM
Mikes65's Avatar
Here is a pic of my 383 stroker in the 65 cutlass. I believe I have a 6 qt pan-fit like a glove.April 15 2012 032.JPG
Old Apr 17, 2012 | 08:21 PM
Mikes65's Avatar
I forgot to ask--what heads are on that motor--they look huge.
Old Apr 17, 2012 | 08:35 PM
gabe442's Avatar
Nice motor did u have to change your frame mounts to do the engine swap? The heads are trick flow
Old Apr 17, 2012 | 09:51 PM
Mikes65's Avatar
Yes the mounts on the frame are chevelle mounts that sit forward of the original 330 mounts. I am a couple weeks away from my first drive--can't wait.
marxjunk
Sep 24, 2014 03:20 AM
pheezy
Feb 8, 2009 04:53 AM
pontchief
20
May 8, 2007 05:06 PM
pontchief
Ninety-Eight
Oct 21, 2006 02:56 PM
MB3110
Aug 20, 2006 04:41 PM
