Vortech 5300 ls swap in a 65 cutlass
Has anyone put the votech 5300 ls 5.3 in a 65 cutlass. Due to the engine being out of a truck (05 Z71) the intake is taller. My mesurements make it apear very close. Does anyone kow for sure?
Thanks Gary
Thanks Gary
When I put a 5.3 in my 72, I swapped out the intake for an LS1 because it looked close. Check over at LS1tech conversion forum for your car. Pretty sure someone's done a 65.
https://classicoldsmobile.com/forums...-iii-swap.html
http://www.ls1tech.com/forums/conver...2-gm-body.html
Well yes and no,i miss the torgue at low rpm,but the chebby makes it out with more revs,10:1 comp and a hyd.roller with 500/510 LIFT .225/231 DURATION @.050" 110º LOBE SEP.
Im still working on a plan to rebuilt the 455 though
Here i a short clip from today cruising,the interesting part is the car in front of me,a `72 W30 cab.(clone) but real nice nontheless,bad quality and shaking but i was driving and filming at the same time
http://youtu.be/nv96dr_g64E
olds70supreme
Aug 1, 2011 05:22 PM
skibone
Apr 15, 2004 03:13 AM
