Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
'64 cutlass engine swap
Old September 25th, 2014, 09:40 PM
ewindgale's Avatar
I am looking at putting in a '95 LT-1 engine in my '64 cutlass but don't have the wiring. Have the computer. This would be my 1st time at such a conversion. What do I need?
ewindgale is offline
Old September 26th, 2014, 06:02 AM
Welcome to the site, I moved your thread here as it will draw a better response, also we do like pictures. A wiring harness, a BOP trans or adaptor plate, misc brackets and wiring changes for accy's, starter, and gauges, engine mount frame brackets etc...
oldcutlass is offline
Old June 6th, 2015, 06:01 PM
dewwhy's Avatar
Motor swap
I have a 1964 olds cutlass f85 and I am putting a Chevy 350 engine in it and I need to change motor mounts or get an adaptor kit, does any one know what to use. I found a adaptor from Jegs #9596 does anyone know if that will work ? My email is dewgraff@Hotmail.com
dewwhy is offline
Old June 6th, 2015, 07:12 PM
You need to treat it like a 64 Chevelle, you need frame brackets and motor mounts. They should work, however I've always used these:
http://www.ss396.com/chevelle/AMC-10SB.html
You'll also need a Chevrolet transmission.
805cut
May 3rd, 2012 08:11 PM
'69CutlassVert'
August 25th, 2011 07:19 AM
oldsmobum
January 14th, 2011 10:10 PM
<jimmy>
November 18th, 2007 02:09 PM
Dread
March 16th, 2007 12:18 PM
Quick Reply: '64 cutlass engine swap
