'64 cutlass engine swap
Welcome to the site, I moved your thread here as it will draw a better response, also we do like pictures. A wiring harness, a BOP trans or adaptor plate, misc brackets and wiring changes for accy's, starter, and gauges, engine mount frame brackets etc...
Motor swap
I have a 1964 olds cutlass f85 and I am putting a Chevy 350 engine in it and I need to change motor mounts or get an adaptor kit, does any one know what to use. I found a adaptor from Jegs #9596 does anyone know if that will work ? My email is dewgraff@Hotmail.com
You need to treat it like a 64 Chevelle, you need frame brackets and motor mounts. They should work, however I've always used these:
http://www.ss396.com/chevelle/AMC-10SB.html
You'll also need a Chevrolet transmission.
'69CutlassVert'
August 25th, 2011 07:19 AM
Dread
March 16th, 2007 12:18 PM
