Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
454 in a 70 Vista Cruiser
Old Apr 4, 2013 | 06:51 PM
doxchopshop's Avatar
I bought a 70 VC, the motor is toast. I have a newer 454 i would put in. Yes I know it is TABOO to the true Olds Lovers, but i was wondering if anyone has done it. I need to find motor mounts or will the Chevelle ones work.
This going to be a functional custom with Hotchkis Susp. I have not seen a Vista done in this way, but i want this to be cool.
Please do not abuse me with the all of the Olds only in Olds stuff, I understand your love. Please understand that I want to build this car to be cool for everyone to enjoy. If it makes it better, the motor will be Gold and the Valve covers will say Oldsmobile on them.
All Advise Welcome
Doc
Old Apr 4, 2013 | 07:33 PM
JIM'S w30's Avatar
doxchopshop
I did that 20 years ago with my car easy to do just use the chevelle mounts and drop it in, if you are going auto use the chev trany for 4 speed use the chevelle Z bar the frame's on a body car's are drilled for everything you need to bolt on did mine in a weekend
Old Apr 4, 2013 | 07:35 PM
thanx Jim
Thank you very much, this was a useful response
drop top olds's Avatar
Old Apr 4, 2013 | 09:37 PM
Yes, the motor mounts and brackets from a Chevelle. Your also going to need a chevy transmission, some exhaust mods, starter wiring needs to move to the other side (I used a ford solenoid and an extended battery cable), all accessory brackets from the chevy motor, etc...
Old Apr 5, 2013 | 04:41 AM
Oldsguy's Avatar
Past Administrator
If you want the vc's gold with Oldsmobile script then go for it, but you and I both know that there are some easy ways to id a bowtie from a rocket by just looking at the top end and any person who is halfway familiar with them will know immediately anyway. I would recommend just keeping the 454 as it would be.
Old Apr 5, 2013 | 08:03 AM
rustyroger's Avatar
'87 Delta 88 Royale
Hotchkiss suspension?, that's new to me.
Can you enlighten me lease?.
Roger.
Old Apr 5, 2013 | 08:09 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Roger.
Looks like you posted on the wrong thread.
Old Apr 5, 2013 | 05:27 PM
Hotchkiss
www.hotchkis.net/
Is a great site for all suspension parts.
Thank a million for all responses. Everyone has been helpful, keep the advise coming.
Old Apr 6, 2013 | 11:00 AM
rustyroger's Avatar
'87 Delta 88 Royale
Thanks Doc, I'm not familiar with a lot of US aftermarket suppliers, now I'm a little better informed.
Roger.
Old Apr 12, 2013 | 08:28 PM
Getting started
I start pulling the old motor in the morning. Plan on cleansing the entire compartment and painting everything.
Old Apr 12, 2013 | 08:37 PM
I did this exact mod with my 67, it's very easy. What transmission are you using.
Old Apr 12, 2013 | 09:54 PM
64Custom's Avatar
I wish you luck with your transplant. I just got finished putting a 454 into my 64 98 Custom Sport, I used a 350 TH tranny. I had a lot of fabrication work for mounts and tranny mount. I also had clearance issues with the oil pan hitting the centre link. You can get aftermarket pans with cut-outs, that fix the problem. My biggest issue is headers, I will need to get a custom set made. I think it's a great fit, and cheaper than building a 455. Good luck!
Old Apr 13, 2013 | 03:53 AM
I bet yours was a bit of a challenge. In your case I would think that the stock manifolds and larger exhaust pipes would work fine. I ran a 440 mag, with stock manifolds and 2.5 inch exhaust in my Fury and installed exhaust cutouts. Man with the cam and open exhaust it sounded sweet and performed well.
Old Apr 13, 2013 | 10:31 AM
64Custom's Avatar
I have an interference issue with my upper A-arms, and I can't squeeze the stock manifolds in. I wish I could, it would be a lot easier.
Old Apr 18, 2013 | 07:00 PM
Pic of the motor
You guys are great, the picture was a huge help. I am running a 700r4
Old Apr 18, 2013 | 08:25 PM
That presents a challenge 64custom, I know that a swap like that into your model is very problematic from others who have done similar swaps.
Doxchopshop, that ought to cruise nicely with that trans. Take pictures of your install.
dan1s
May 19, 2008 05:52 AM
72droptop
Dec 25, 2007 05:19 PM
shaks 442 clone
May 31, 2007 08:42 AM
dustyk70
Mar 7, 2007 07:21 PM
grandmas73rocket
Nov 23, 2004 04:51 AM
