Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Chevy 350 build help
Old Jan 20, 2013 | 03:52 PM
VinMichael's Avatar
I have a 4-bolt main Chevy 350 at the machine shop bored 60 over. I bought a set of flat top Speed Pro cast pistons for it.
The heads are #3932441 76cc combustion chambers
I plan on running a stock HEI, an Edelbrock 4-barrel carb, and an aftermarket cam/valve springs.
I am wondering how much HP/TQ I could get out of it with stock heads and intake/exhaust manifolds.
Old Jan 20, 2013 | 03:55 PM
redoldsman's Avatar
Proud Viet Nam Veteran
You are going to need to go to one of the Chevy sites to get what you are looking for. This is an Oldsmobile site.
Old Jan 20, 2013 | 03:59 PM
VinMichael's Avatar
This is the Non-Olds Powered section
Old Jan 20, 2013 | 04:08 PM
redoldsman's Avatar
My apologies. I doubt you are going to get much help there. There are a lot of us on here that have built Chevys but it has been a long time for me. I hope somebody can help. One of the Chevy sites is still probably going to be your best bet.
Old Jan 20, 2013 | 04:14 PM
Ed Carpenter's Avatar
Somewhere between 250 and 300 HP range. The heads don't flow the best and 76cc will keep your compression at the low level. A good set of heads will wake it up. Try your luck at http://www.chevelles.com
VinMichael's Avatar
No problem. I figured I'd ask here before I went out and made an account at a Chevy site. Just throwing it out there.
Old Jan 20, 2013 | 04:31 PM
VinMichael's Avatar
That's what I assumed. That may even be enough ponies since it's going in a 65 Nova, really light car. But of course, I want to get the most out of what I have.
Old Jan 20, 2013 | 04:57 PM
Somewhere around 300, plenty for a Nova. What powertrain are you using? Got pic's?
Old Jan 21, 2013 | 08:34 PM
GetDown's Avatar
Definitely not over 300 with stock intake/exhaust manifolds. There's no point in doing an aftermarket cam either. A stock chevy 350 can come really benefit with just aftermarket intake/exhaust. I would go that route before changing any internals, especially if you are running higher compression and .060 over.
Old Jan 22, 2013 | 03:13 PM
VinMichael's Avatar
I'm running 9:1 compression. Well, I'm def not running the cam that came with it because it has a flat lobe. I have no choice but to go aftermarket.
Old Jan 22, 2013 | 03:17 PM
VinMichael's Avatar
I'm planning to run a TH350. I think the rearend has 3:23 gears in it but I'm not 100% positive.
GAOldsman's Avatar
"Car"mudgeon
Tons of helpful info here as well as great feedback to most all questions that you may ask. As many of these questions have been asked before it is always a good idea to do a search and if you can't find it that way, the folks are always eager to help.
Old Jan 22, 2013 | 03:18 PM
GAOldsman's Avatar
"Car"mudgeon
That's a nice Chevy II
Old Jan 22, 2013 | 06:17 PM
61reoldsman's Avatar
Get a 350 hp 327 cam that'll bring it too life The 350HP-327 cam was used in tens of thousands or even hundreds of thousands of daily drivers. After it was developed it was found to be the best compromise between HP and efficiency and used in many Chevy applications without making a big hoopla about its 350HP origins.
In perhaps plainer English it began as a hot rod factory cam and ended as a stock cam for much of production.
Old Jan 22, 2013 | 06:34 PM
VinMichael's Avatar
Thanks a lot for the cam suggestion. Sounds very suitable for this project. I looked it up on YouTube and I like the sound. Do you think it would help me get close to 300 hp?
Old Jan 22, 2013 | 06:50 PM
Well don't forget the factory rated hp without power robbing accessories back in the day, so that 300hp was at the crank not at the wheels .Shouldn't be a problem achieving that goal nowadays with proper block prep and machining .I had a 67 Chevy 2 when I was younger and built up a big 6 cylinder for it and that engine hauled in around very smartly ,wasn't 300 hp but I bet I had 250-275hp with a 4 bbl Clifford manifold and a 600 Holley and headers ,sounded like a big bumble bee !Anyways a 350 will be fun in that light car.
Old Jan 23, 2013 | 06:36 AM
Nice solid Nova from the looks of it.
Old Jan 23, 2013 | 08:51 PM
GetDown's Avatar
you can't build power if you are restricting the air coming in and going out... remember an engine is essentially an air pump.
Old Jan 23, 2013 | 11:40 PM
Aceshigh's Avatar
76cc ?? It will be a pig. This is coming from a Chevy engine fan mind you.
Late 70's Chevy pig motors with 170-195hp / 300ft lbs of torque. That's about it.
They're still selling them as 260hp (GROSS) motors.
http://www.jegs.com/i/GM-Performance...67353/10002/-1
But once you put on all the accessories, and actually get it INTO the car, it's NET hp rating is <200hp.
It's not even worth the effort unless you just want to get the car running to sell it.
Investing $$ into a weak motor build like that isn't very fruitful.
Key to HP is head flow.
Your better off tossing the worthless heads, buying aftermarket heads that actually flow air.
However, by the time you invest all that $$$ into an old technology engine, you will realize
you could have just bought a scrapyard LS drivetrain with overdrive for the same investment with more HP.
Old Jan 24, 2013 | 06:30 AM
Those are the standard 1.96 heads, I prefer the 2.02's for sbc but they will work fine for a cruiser. With a bit of milling and a thin head gasket, that cam, headers, 600cfm carb and dual plane intake - 300 horse.
Old Jan 24, 2013 | 11:00 AM
Hey have a look at the specs of this crate engine ,makes 330hp@5000 ,380ftlbs@3800 -http://www.crateenginedepot.com/350-Crate-Engine-330-HPBase-HO-with-Iron-Vortec-Heads-19210007-P9417.aspx
Old Jan 24, 2013 | 10:37 PM
GetDown's Avatar
that about sums it up
Old Jan 27, 2013 | 01:21 PM
VinMichael's Avatar
Yeah I know, but headers for these cars are a PITA and are expensive.
The idea is basically to get a motor together and get this car running. I can always put new heads and exhaust on the car later, so what you said about investing money into this engine being a bad idea really doesn't make sense. I never even stated what part of the engine I'm spending my money on. I'm just trying to get the most out of what I have and get the car to run the best that it can given what I have. And I'm definately not putting an LS engine in it. lol
I just want to get it running well, and with minimal effort.
Thanks for the input man, that's the type of info I'm looking for.
I'd really like to run the Vortec heads, but they are kind of a hassle. They need self aligning rockers and can't take much valve lift in stock form. They are a great head for the money, and I know people who have ran quick 1/4 mile times after bolting them on. They also won't work with stock manifolds and I need to run stockers because the Nova has such narrow shock towers.
Old Jan 27, 2013 | 05:02 PM
Even with the standard exhaust manifolds, a little lopey cam sounds great for a cruiser. It does not have to burn down the 1/4, it just needs to sound nice and be dependable. Let us know how it goes.
Old Feb 24, 2013 | 12:59 PM
VinMichael's Avatar
This car is now up for sale if anyone is interested.
Old Dec 22, 2013 | 08:25 AM
49olds 88's Avatar
76 cc heads with flat or dish pistons??flattop about 9 to one compression, 8 to one with dish. I have been racings 350,s for over 40 years. my e mailkyzercd71@yahoo.com
Old Dec 23, 2013 | 05:40 AM
49olds 88's Avatar
the 330 hp crate motor which I have is also sold as a 350 hp to racers, identical specs. The 330 cam is a good cam, but I ran a 327 350 hp cam in three diff cars. Has a good lope and pulls well even in tow vehicles. I put a crower cam in mine so it will lope thru car gathering at burger king
Old Jan 13, 2014 | 04:47 PM
VinMichael's Avatar
Well I sold the car I was gonna put this engine in. However, I'm still planning to build it. I want to maybe put it in the Olds.
I've been looking into Vortec heads for it. I've learned that they need self aligning rocker arms and should probably need to be machined for lifts bigger than .480".
Maybe I'll have a 12 second car with this engine?
Old Jan 13, 2014 | 04:54 PM
Welcome back, I would say closer to 14-15.
Old Mar 13, 2014 | 01:55 PM
49olds 88's Avatar
engine
you can run the 350 hp, 327 heads without maching the rocker studs. the cam that comes with the 330 hp 350 has a good set of specs. I sold the cam out my 330 hp and went with a crower just for a little more lope, had to have studs cut a little. ran a set hopped up vortec heads from brezenski and won 3 track championships with this motor. it would turn 7300 and still be pulling, although they were highly modified. had 194,s and 160 exaust in them,
Old Mar 13, 2014 | 02:07 PM
  #31
7300 rpm, an accomplishment
Old Mar 13, 2014 | 02:09 PM
  #32
11971four4two's Avatar
MOTORHEAD
I have stock cast iron exhaust manifolds on my truck with vortec heads. If you keep the lift to .474 or so the factory springs are fine
Old Nov 22, 2014 | 06:28 PM
  #33
schoenchen144's Avatar
I have a 350 and it has stock compresion pistons, and bored .040 over. I put a set of vortec heads on it and this cam.http://www.summitracing.com/parts/cr...make/chevrolet
it runs really good, very nice acting cam, 600 edelbrock carb, but I had headers. You can run stock exhaust but it will breath better with heders. Stock converter, aftermarket intake. I dont know if its over 300 HP but its very close.
I had the heads rebuilt and the valve guides cut down to allow a higher lift cam, new springs and seals, you can pretty much buy vortech heads from summit ready to go with a high lift ready set up as cheap as buying used heads and rebuilding them nowdays.
moys71
Feb 16, 2021 08:22 PM
cutlassefi
May 23, 2019 06:42 AM
507OLDS
Jan 29, 2014 07:25 AM
507OLDS
Mar 24, 2012 07:34 AM
69 442 protour
Dec 9, 2006 09:25 PM
