Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
64 f85
Old Aug 4, 2013 | 07:26 PM
P Dean's Avatar
64 f85
I am building 64 F85 conv with 04 GTO LS1/4L60 power. To date have beenDealing trunk rust, love the way repo sheet metal fits!
Old Aug 4, 2013 | 08:43 PM
I have a friend who used a complete 04 GTO powertrain on his *****'s Aero.
Old Aug 4, 2013 | 08:46 PM
oldstata's Avatar
Justin
Welcome.
Pics !! Please
Old Aug 4, 2013 | 09:00 PM
P Dean's Avatar
Pic's
I haven't figured out how to post pic's, sorry.
Old Aug 4, 2013 | 09:02 PM
oldstata's Avatar
Justin
Lol
I use a off sight such as photobucket and copy the IMG
Paste in replay and it s right in the text
Old Aug 4, 2013 | 09:07 PM
P Dean's Avatar
Pics
There is a picture of car as it now on my bio. I have bought S&t pan,hopeTo start install in a couple of weeks.
Old Aug 5, 2013 | 05:16 PM
jag1886's Avatar
As much as I spent on my engine and transmission I kick myself for not doing a late model conversion. My car is just a Cutlass as people say when they walk by at car shows, so I should have upgraded all the way to a modern LS/overdrive setup.
Old Aug 5, 2013 | 05:22 PM
oldstata's Avatar
Justin
That's odd when I took mine I had A few that loved seeing something other than the camaros or mustangs
And a few that thought it was a Chevell I even had a few that asked what is that ?
Old Aug 22, 2013 | 07:28 PM
Aceshigh's Avatar
Same powertrain I picked up with only 26K in 2006 for my pro-touring 78z.
I loved it so much........I bought a 2008 6.0L LY6/T-56 setup for my 1970 Olds I'm currently doing.......still....after 2 years....lol
Old Aug 22, 2013 | 07:31 PM
Aceshigh's Avatar
I went through this from 2002-2006 also doing build sheets from everything from a
500hp 383 stroker (equal to an LS3) to a BBC, to 700R4's, etc.
Finally I woke up and realized the LS powertrain was the best bang for the buck.....of course after
blowing loads of cash on new Gen I motors and 30 year old built OD transmissions I sold later on.
These GM corporate Gen III and IV small blocks can put out the same power as the big
blocks with far better efficiency for pro-touring builds......meaning drivability. (Full on drag racing cars is another discussion)
Something that many fail to realize is every classic motor is rated by GROSS hp, (Pre-1972)
Even the one's every Tom, Dick, and Harry at a car show had built or rebuilt is rated the same way.
LS motor's are rated by SAE NET hp (post 1972). So when you compare a 455 making
360hp 500lbs ft to an LS2/LS3/LS7. The LS motors will top them in every category.......
A 14 second 442 will go into the high 10's, and 11's quickly........... >
http://www.lateral-g.net/forums/show...89&postcount=3
(example with 66 Chevelle)
The LS3 for example is rated 430hp SAE NET but that's closer to 500hp Gross HP.
I want an LS7 ..........hence the avatar.....nearly 600hp from the factory GROSS hp.
Old Oct 1, 2013 | 05:30 PM
65-F85's Avatar
help with LS swap
I am putting a ls1 in a 65 f85/cutlass/holiday. I am having a hard time getting it to sit on the motor mounts because of k-member and clear the steering components. can you help me with this.
You can call 601-214-8491
I have a lot of bucks already tied up in this swap. and I have hit a brick wall
Gary
Old Oct 22, 2013 | 06:42 AM
kainedogg's Avatar
Not sure how simiar these cars are to the Lemans\GTO but I used a CTS-V gen 1 oil pan and Chevelle engine mounts. Everything cleared with little issue. If you get adustable mounts like Dirty Dingo then you have even more options.
mikkim129
Apr 27, 2016 03:49 PM
BIGBAD455
Cars Wanted
Feb 1, 2010 07:17 PM
oldolds
Aug 23, 2007 06:33 PM
<c. larson>
Cars Wanted
Sep 23, 2006 05:57 PM
ssaltuc
May 15, 2006 06:59 AM
