power disc brakes 64 f85
Old Mar 5, 2004 | 10:36 AM
<c. larson>
Guest
Posts: n/a
Post
i have 64 F 85 olds with manual drum brakes, anyone know if there may be an easy swap from chevy nova,chevelle or others to convert to power disc up front and retain the rear drum. thanks
Old Aug 21, 2004 | 05:08 PM
mrolds88's Avatar
Post
Best bet is to use 69-72 gm A body (Cutlass, Chevelle,Lemans,Skylark, Monte Carlo,Gran Prix(I think). ALso look for the wagons too. Pull everything that you can. Make sure that you get the proportioning valve on the frame almost directly under the Master cylinder. Get the spindles too, will save a lot of hassle. Try to stay away from the 67-68 stuff, they use some odd and expensive parts. Hope this helps. Greg
Old Sep 23, 2006 | 05:57 PM
Droptop's Avatar
ive seen some conversion kits on ebay, think they were about 450.00 . not hatefull concidering you get new parts and can go bolt them on without the hassle of getting used parts off another car and having to resto them before putting them on yours..
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
501Paratrooper
May 29, 2010 08:38 AM
63CUTLASSCONV
May 18, 2010 03:13 PM
flaharleyguy
Feb 23, 2010 05:32 PM
