Power Disc Brakes?
Old Feb 22, 2010 | 04:05 AM
flaharleyguy's Avatar
Power Disc Brakes?
Has anyone installed front disc brakes and firewall mounted booster on a 54 55 or 56? If so I would appreciate any help! Thanks
Old Feb 22, 2010 | 07:35 AM
citcapp's Avatar
I did it on my 57 Olds. had to remove the drivers side fresh air bump and install a flat steel plate, then used a hanging pedal out of a 1975 Olds 88. Used a dual diaphram 8" booster to clear the engine. Had to heat up and rebend the brake pedal assembly to locate it correctly because it mounts to the left of the steering column. Worked out fine.
Old Feb 22, 2010 | 07:47 AM
Thanks did you add any extra bracing for the hanging pedal or was the steel plate sufficient? I assume it was 3/16 or ?
Old Feb 22, 2010 | 07:50 AM
citcapp's Avatar
I used 3/16 steel plate and ran a brace from the hanging assembly to the dash/steering colum bracket area.
Old Feb 23, 2010 | 02:13 PM
hialeah56's Avatar
1956 holiday coupe
I'm going thru this right now. Got my disk brake kit from scarebird on ebay and just got my new brake booster. Only thing is I'm still trying to adapt my pedal probably going to use a 58 buick pedal
btw got some pictures of the brakes on my topic
Old Feb 23, 2010 | 03:06 PM
Did you have to get different wheels to clar the calipers? Thanks for pics!!
Old Feb 23, 2010 | 05:32 PM
citcapp's Avatar
You have to go to 15" wheels to fit the calipers. 14" won't clear
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
DouglasOliver
Mar 13, 2012 11:27 AM
russell-t
Apr 30, 2011 05:56 AM
501Paratrooper
May 29, 2010 08:38 AM
<c. larson>
Cars Wanted
Sep 23, 2006 05:57 PM
