Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Engine mounts/frame pads
Old Sep 12, 2011 | 06:23 AM
panos's Avatar
Anyone knows what mounts/pads i can use for a L31 sbc into a 65 cutlass?
Old Sep 12, 2011 | 07:29 AM
You would need to treat it like a 1965 Chevelle. Your car is an A body just as a Chevelle. You will need the frame brackets and the matching motor mounts, to perform the swap! Also if you have a bop trans, you will have to get an adapter plate or a chevrolet trans to mount up.
Are you planning a swap to replace the 455?
Old Sep 12, 2011 | 08:48 AM
panos's Avatar
Well im thinking about it a good friend of mine did me and offer that is hard to say no! a 1 year old sbc 350 with brand new block alum.heads(afr) scat rottating assem. etc,he says its pushing around 410hp.Reason he sells it is he is building a 421 for his nova.
Old Sep 12, 2011 | 09:09 AM
I'm in the process of doing a similar swap on my 67!!! I'm installing stroked 454/T400 trans! So far it's been really easy, just a few minor details. I used BBC frame brackets with BBC motor mounts. I have a ministarter on the BBC so I went with a Ford Solenoid for starter and ign circuit power to the HEI. I had to move the trans Xmember back and now am modifying my e-brake to work. I also have to mod the driveshaft. I reused my olds alternator with BBC brackets. I also used the BBC power steering pump and modified the hose! I used BBC Hedman headers for a Chevelle.
I hope to have it all back together and running in the near future!
joesw31
May 31, 2015 04:17 PM
Se7enty5
May 12, 2015 08:48 AM
88hurstolds
Mar 6, 2014 09:03 AM
Nasty455
Mar 20, 2012 04:57 PM
76Supreme350
Sep 13, 2011 03:31 PM
