Engine spray paint
Engine spray paint
Where can I buy the correct color SPRAY paint for a 1953 OLDS engine? I've had no luck thus far finding it locally. Goggle hasn't turned up much either once I dig into it.
I'm doing an LS swap but have some tricks to make it look more original. paint color is obviously one of the key factors to making it appear stock to the un trained eye.
Thanks.
Thanks.
You can buy spray cans from Fusick and you can buy quarts from Bill Hirsch. Hirsch may have spray can but I don't remember. Both are pretty good but I don't know if they are good enough to make an LS look like a 303.
Thanks!! I'll start there.
This is what I'm going for but with a cover over the stock intake instead of the carb based intake.
http://www.hotrod.com/how-to/engine/...-rocket-style/
