Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Ls swap problems in 65 f85/cutlass/holiday
Old Oct 1, 2013 | 06:01 PM
65-F85's Avatar
Help, I am putting a ls1 in a 65 f85/cutlass/holiday.. I am having trouble getting it to sit on motor mounts because of the k-member and stearing linkage. There is one I find on Hot Rod mags page. I am trying to find out Who it is? and a contact number.
Is a olds A-body different that a chevy A-body at the k-member??
Help please !!
Old Oct 1, 2013 | 06:11 PM
72cuttys's Avatar
There is a section at the bottom of the forum for non-olds powered cars. Check there for multiple ls swap threads.
Old Oct 1, 2013 | 07:02 PM
The only difference is the engine frame brackets. There are a few folks doing LS swaps as mentioned in the non-olds powered section. You may want to PM on of them.
Old Oct 1, 2013 | 09:43 PM
I moved your post to a new thread. Good luck with your swap.
Old Oct 2, 2013 | 01:29 AM
garys 68's Avatar
What oil pan are you using?
Old Oct 4, 2013 | 04:17 AM
firefrost gold's Avatar
lets see some photos on the upgrade please.
Old Jan 18, 2014 | 04:04 PM
65-F85's Avatar
finally in there
Well the LS is finally in and running. It was not easy. It took the Street & Performance out of Mena AR. we tried the hooker from jegs for a-body cars and it did not work. Real Pleased. I put a small cam in a 5.3 lm7 and a 4l60e trans. Now own to Brakes to stop the beast......
Old Jan 18, 2014 | 04:09 PM
Pictures???
chasman414
Jun 25, 2020 07:05 AM
64Olds98
May 5, 2015 06:30 AM
65-F85
Non-Olds Engines
Oct 1, 2013 05:07 PM
Olds Dad
Dec 27, 2010 11:03 AM
toyktdlgh
15
May 14, 2008 06:52 AM
