Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Edelbrock carb on a 78 Vette L82
Old Jun 18, 2012 | 02:55 PM
Howdy group.
This carb looks like the quad that it replaced. The PO said the quad gave him trouble and swapped in the Edelbrock. The engine only has 27000 miles so I can't imagine what trouble it gave.
Anyway, I replaced the fuel filter and now I can't get the housing to stop leaking. There's some sort of fibrous gasket inside and I'm wondering if it's become deformed or something and no matter how tight I get it the housing still leaks. I don't believe it's stripped but it doesn't move very freely, even at the beginning threads.
So, what's a good plan of attack here, seek out a new fibrous gasket, get a different kind of gasket? Tighten it till it strips then back off a 1/4?
I have the quad that was original to the car. I have no idea what shape it's in. Anybody have an opinion as to which is better? The car runs like a champ with the Edelbrock and I wouldn't change it ordinarily, but I can't drive with the carb leaking that would be silly.
Thanks much.
Old Jun 18, 2012 | 04:31 PM
Which Edelbrock carb is it? I don't believe they have filters in them.
Old Jun 18, 2012 | 06:57 PM
It's the Performer 1903. Looks just like a Quad. Yes it uses the same fuel filter as the Quad also. I hope I didn't crack the housing or gall up the threads too badly.
Old Jun 18, 2012 | 10:05 PM
Rickman48's Avatar
Having built several L-82's, I'd say either rebuild the original carb, or order a direct replacement for it.
Although a 'pollution carb', a little tweaking can get them to run pretty hard, if you know what you're doing.
It is jetted for that application, whereas the Edelbrock is very generic.
Old Jun 19, 2012 | 04:21 AM
garys 68's Avatar
Is the edelbrock new? Sounds like you stripped or cracked something. It's pretty common to see Qjets stripped there.
Get a rebuild kit for the original Qjet, put it back on.
Old Jun 19, 2012 | 06:35 AM
Wow, you learn something everyday, I don't believe I have ever seen one of those! There should be a gasket in there to seal the fitting to the housing.
bccan
Sep 11, 2013 08:14 AM
cutlass xombie
Wheels and Tires
22
Jan 19, 2012 06:06 PM
tj78_
Cars Wanted
Aug 2, 2011 11:46 AM
made in the usa
Feb 15, 2011 07:27 AM
vettemad
Mar 21, 2010 04:41 PM
