Click Here
Vette rally rims???
Old Jan 12, 2012 | 06:47 PM
cutlass xombie's Avatar
Vette rally rims???
1969 Vette rally rims 15x8 with 295/50/15 on the back and 275/60/15 on the front.
I know the bolt pattern is the same but would I run into trouble with them rubbing on anything?
Old Jan 12, 2012 | 06:51 PM
They should have enough offset to work just fine. They are a great looking wheel. Same as what they eventually also used on the 73-77 Chevelles.
Old Jan 13, 2012 | 02:06 PM
Thanks Allan....I've always loved these rims as well and have a chance to get a nice set with almost new BFG's on them so just wanted to make sure I wouldn't run into any probs if I do decide to get them.
Old Jan 13, 2012 | 02:25 PM
I'd go for it too. IMO they're a classy wheel. Best part is you can color code the steel parts to whatever color you want, or just leave them stock. I think you can get center caps that are generic and don't have Chev on them. Another good thing is they are designed to fit disc brake cars, so if you ever change over your front to discs, you're a step ahead. Can't wait to see them on your car!
I know I've seen older chevelles with SS11 and SS111s. Why not have a Cutlass with vette rally's?? 2 thumbs up bud!
Old Jan 13, 2012 | 02:59 PM
ya discs are going on the front eventually lol...so it's good to know that they will fit when I do make the swap. Right now I am just focusing on getting it road worthy for the spring and next summer. It won't be pretty but it'll be on the road lol...and safe.
I am hoping to go take a look at them on Sunday.
Old Jan 13, 2012 | 03:07 PM
How much on average would a set go for in really good condition with good rubber?
Old Jan 13, 2012 | 03:16 PM
Mak's Avatar
Mak
Here's a used set in CA... caps, but no rings: http://sfbay.craigslist.org/eby/cto/2788751857.html
I'm looking at these... not as cool, but still pretty nice looking:
http://www.ebay.com/itm/380400575756...ht_5446wt_1185
Old Jan 13, 2012 | 03:46 PM
Thanks Mak....those ones on Ebay are almost identical...hard to tell the difference. I'd say if you can't find some original ones then go for it...pricey though lol...that's why I'm going the used route
Old Jan 13, 2012 | 04:00 PM
Mak's Avatar
Mak
pricey though lol
Not too bad... (that price is for set of 4)
Old Jan 13, 2012 | 04:02 PM
lol oh I thought it was for one...ya that is pretty good...now I would say go for it for sure
Old Jan 13, 2012 | 05:03 PM
z11375ss's Avatar
Senior Moment Member
Those are a buy at that price.
Old Jan 13, 2012 | 05:24 PM
allyolds68's Avatar
I can't speak to how the offset effects it but that size on the front won't fit an a 68 no matter what the offset. I can't imagine them fitting a 67 either.
In this thread Joe P says diameter should be under 27". Those tires are 28"
https://classicoldsmobile.com/forums...-question.html
Old Jan 13, 2012 | 07:38 PM
vette442's Avatar
My '70 SX ragtop had 15" Corvette rally wheels on it when I bought it and I drove it from IL to PA with no rubbing issues at all. It put SSIs and Radial T/As on it shortly after arriving at home. With my user name, it's obvious that I like the Corvette rally wheels too. ; )
Terry
Old Jan 13, 2012 | 07:49 PM
Terry
Terry, I'm also a fan of those wheels. Anything you can suggest about why they shouldn't work on a 67? I thought the bolt pattern was the same from 64-81.
Old Jan 13, 2012 | 08:05 PM
gearheads78's Avatar
car guy
I don't see a 275-60 getting anywhere near fitting the front.
Old Jan 14, 2012 | 03:31 PM
What is the max size that would fit?
Old Jan 14, 2012 | 04:33 PM
hookem horns's Avatar
I've got 255/60/15's on 7" rims in front. Slight rub at full lock, worse if bumpy. Can't imagine anything bigger without modification.
Old Jan 14, 2012 | 09:50 PM
z11375ss's Avatar
I put a big *** Hotchkis sway bar on the front and noticed I have a small rubbing issue with the 275/60/15. That is on regular Cutlass wheels however. I have a 1971 LT1 Corvette and run the 8 inchers on that with no rub, obviously. Love that look.
Old Jan 16, 2012 | 02:49 PM
So it sounds like I would be better off with the aftermarket rims than the ones from the Vette and go with a 70 series tire?
Old Jan 19, 2012 | 11:54 AM
droptopron's Avatar
delete
The rims sjould be OK. Its the 275 that sounds too big. i fthey are local and mounted up try them on before you buy. if theya re too big a 245/60 should fit on the front on a 8".
Old Jan 19, 2012 | 03:24 PM
Thanks droptopron...That makes sense now..duh!
Old Jan 19, 2012 | 03:44 PM
I run the 275's on the rear of my car and could not fathom putting anything that wide on the front. If your running the stock height on the car you can run that tall of a tire, I would go a tad narrower. Btw, I'm a big fan of Corvette Rallies!!
Old Jan 19, 2012 | 06:06 PM
Redog's Avatar
295/50/15's do fit on 8 inch wide wheels.
I know they fit on the rear of a 71 Cutlass no problem
bccan
Sep 11, 2013 08:14 AM
slantflat
Non-Olds Engines
Jun 19, 2012 06:35 AM
tj78_
Cars Wanted
Aug 2, 2011 11:46 AM
made in the usa
Feb 15, 2011 07:27 AM
vettemad
Mar 21, 2010 04:41 PM
