Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
AMC QJ problems
Old Aug 6, 2015 | 05:34 PM
bw1339's Avatar
AMC QJ problems
Hello,
I have an AMC 360 engine with a QJ. The engine will only idle with the idle screw all the way in, starting to run on the primaries.
The engine has 9.6:1 compression and a Lunati Voodoo 262/268 cam, as well as a quadrajet. The carb I rebuilt myself (first time, so I may have messed something up), number 17058253, which does not have idle air bypass. I started with the idle screws one turn out and turned them 1/2 turn at the time, with no results. Timing is 20deg initial, 35 total. When I rebuilt the carb, I blew compressed air through the idle circuit and everything seemed clear.
I have the same cam in an Olds 455 and it idles quite nicely, with a slight lope.
Any suggestions?
Thank you.
Mikel
chasman414
Jun 25, 2020 07:05 AM
Marshtonk
Dec 18, 2014 02:15 PM
Mr Shifty Sidney
Aug 18, 2014 07:32 PM
Sampson
Jul 12, 2013 04:58 PM
nukesec1
Apr 9, 2010 06:31 AM
