Small block Chevy lifter/ pushrod problem
So I had a reman engine dropped in my 94 Sierra 4x4 and it’s been nothin big problems bc the people I took it too must be hacks. I thought I was saving myself time but now it’s cost me a bunch of money and time so I shoulda done it myself. Oh well lesson learned. The intake started leaking so I changed the intake gaskets myself and changed the oil and attempted to start the truck. It ran but it had a wicked tick coming from the passenger side bank. I pulled the valve cover and checked with a stethoscope and found it to be cylinder 4’s exhaust valve. I checked the lash adjustment and u can’t spin the pushrod at all. I took the rocker off and u can’t even pull the pushrod out or spin it at all it won’t budge. Is this the sign of a stuck lifter or something worse? I put riselone in the oil and tried running it but I could see that it’s not getting oil up that push rod so I stopped. I sprayed penetrating oil down the push rod and let it soak to see if that would free it up and it didn’t do anything
what could this be? Does this mean I gotta take the intake back off and change the lifters or did I wipe out part of the cam I don’t understand
there’s a crazy story to this engine and the people who put it in that’s way too long and complicated and basically it’s had to be warrantied out twice and I’m at the point where If I want it done the right way i gotta do it myself
Olds power it, the Olds 350 was a welcome upgrade in my 94 Z71. Yes, you can run the factory TBI with a 307 CCC distributor. Same wire colours, ground the extra black wire and advance the base timing, 10 to 20 degrees. The F body 403 mounts basically work and get the Transdapt bellhousing adapter. The truck is trying to tell you something😉.
dd,
I just now thought of something. You had the intake off ?? On small block Chevy engines there are a couple of intake bolts that will hit a pushrod if you put too long of a bolt in the wrong position. Any chance that is what happened ?? That will lock up a pushrod for sure.
dd,
I ended up taking the intake off and changing all the lifters and put the intake back on and now the # 5 exhaust is doin the same thing #4 was on the other side of the motor
maybe I got a bolt that’s too long that I keep sticking in the middle of the manifold but this time I put it on the other side of the intake I’m gonna look into that for sure
dd,
