Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
66 vista update
Old Jun 15, 2025 | 04:15 PM
Bennelli's Avatar
66 vista update
I don't see much discussion about engine updates here, but I'm thinking doing a LS swap. Has anyone done this? I've done many engine swaps, but wondering about the trans clearance. A 4l80 should be no problem, wondering if 6l80 will fit.
Old Jun 17, 2025 | 09:51 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Won't be much info on CO but a few have done it, not cheap or super simple. Boost is the great equalizer, the stock 6L/6L80E in the 3/4 ton work truck is beyond useless below 3500 rpm. Not great for a heavy wagon. For EFI, I suggest an entirely new and separate wiring harness. The later 4L80E needs the floor clearanced for the center cooling lines, mine needed pretty good dents. Guys in G bodies have ran the 6L80E with minimal floor work.
Old Jun 17, 2025 | 10:29 AM
Bennelli's Avatar
Ls/ 4l80 swap
Thanks for trans info. I've done several ls swaps, last was a 51 caddy with truck 6.0 and 6l80. Gen 2 Camaro front stub. That was pretty tight, but worked great. I think the 4l80 is same size as th400. Pretty big unit. 700r4 is slightly slimmer, I'll have to jog my memory and do some research.
Old Jun 17, 2025 | 10:32 AM
Bennelli's Avatar
Oh, by the way I have done swaps using both stock harness and after market. Just takes a little more time.
Old Jun 17, 2025 | 04:33 PM
I tied a Holley Terminator harness into the 50+ year old harness, a fire happened. Doing multiple swaps should make it easy.
Old Jul 11, 2025 | 05:51 AM
CutlassMarc's Avatar
I'd got straight to the lt1 or 4 and ten speed.
F-85 4-4-2
Nov 29, 2024 02:56 PM
Oldslow
Feb 11, 2020 06:13 AM
66-3X2 442
Cars Wanted
Dec 18, 2018 12:59 PM
35tac
Mar 28, 2016 01:09 AM
