Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Engine stalling
Old Jul 15, 2019 | 07:52 PM
Ben heras's Avatar
Engine stalling
I put a rebuilt 327 and rebuilt turbo 350 in my 85 Cutlass and it idles fine but when put into gear my engine stalls my timing is correct I rebuilt the carburator ,bought a new distributor because top was cracked, I don't have everything ,temp sensor oil sensor hooked up, why does my car stall
Old Jul 15, 2019 | 07:57 PM
327? What distributor did you buy? What carburetor is no it? What is your timing set to?
Old Jul 15, 2019 | 08:29 PM
Ben heras's Avatar
327sbc ,Accel gm hei performance,,Carter afb competition series 4 barrel ,10 degrees before tdc
Old Jul 15, 2019 | 09:24 PM
Set your timing to 16*, set your idle speed to 750.
Old Jul 16, 2019 | 08:55 AM
Ben heras's Avatar
Timing is reset but low or hi rpm it still dies
Old Jul 16, 2019 | 09:23 AM
What about your carb a/f mixture screws, did you adjust them? Is the 327 stock?
Old Jul 16, 2019 | 04:36 PM
Ben heras's Avatar
They are at 2 1/2 turns each and I believe it's stock not sure ,what's the difference?
Old Jul 16, 2019 | 07:09 PM
You need to set them with a vacuum gauge for the highest vacuum.
Old Jul 16, 2019 | 07:10 PM
Ben heras's Avatar
Cool I'll buy a guauge tomorrow after doing that's what would be my next steps
Old Jul 16, 2019 | 07:19 PM
Whats the idle rpm?
Old Jul 16, 2019 | 08:06 PM
Ben heras's Avatar
I'll have to see tomorrow but I went out and adjusted my carburator a hair to see if I can get any results and I did get the car to not stall a little I'm pretty sure that's probably what it is I'm going to buy a vacuum gauge and fine tune it tomorrow ,I'm just looking to get the most vaccum correct? How should I go about starting that, do I adjust from where I'm at or start from scratch
Gone Johnson
Mar 27, 2019 07:42 AM
Mrgadget
Jun 30, 2018 02:56 PM
tgilligan
Aug 11, 2017 06:54 PM
Charly9g
May 11, 2016 03:09 PM
Hurstolds1973
May 5, 2013 06:49 AM
