Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
402 bbc with 400 turbo tranny
Old Feb 11, 2019 | 05:29 PM
72_Delta_Vert's Avatar
Hi im new to the whole classic cars world only 24. I have a 72 delta 88 and want to know whatvi have to do to put a 400bbc and trans into my olds. I know motor mounts and the old pan but what else. Thankss
Old Feb 11, 2019 | 08:38 PM
edzolz's Avatar
Originally Posted by 72_delta_vert
hi im new to the whole classic cars world only 24. I have a 72 delta 88 and want to know whatvi have to do to put a 400bbc and trans into my olds. I know motor mounts and the old pan but what else. Thankss
why
Old Feb 11, 2019 | 08:58 PM
Hello, and welcome to the world of classic cars. In here, most of the people who own cars try to keep at least the same brand of engine in them as they are, and we definitely do that here.
You should consider an Oldsmobile 455 for that Delta 88, it will be more fun, and you can keep your Olds all Olds.
Old Feb 11, 2019 | 09:10 PM
Welcome to the site. You'll need engine mounts, frame pads, may have to move trans xmember, drive shaft depending on transmission, and some minor wiring changes due to the starter being on the other side of the engine and the location of the gauge senders. If you don't have all the accy brackets for the 400, you'll need them also. It would be far easier to go with an Olds engine.
Old Feb 12, 2019 | 06:51 AM
but what else.
EVERYTHING else.
Motor mounts
Frame pads
Trans (and it needs to be a long tail TH400, not a short tail)
Accessory brackets
Pulleys
Belts
Wiring
Starter
Exhaust pipes
Exhaust manifolds
Fuel lines
Hoses
Heater control valve
Radiator
Old Feb 12, 2019 | 06:56 AM
lemoldsnut's Avatar
Joe is correct With one exception. The stock original radiator should work just fine.
Old Feb 12, 2019 | 07:08 AM
I was thinking the Chevy radiator had different inlet/outlet configuration, but that's the extent of my Chebby knowledge...
Old Feb 12, 2019 | 07:17 AM
lemoldsnut's Avatar
Joe, Your knowledge is amazing. Baffling sometimes how much wisdom or at least access to the research documentation you have. I appreciate it so very much.
Take care fellow Olds Nut
Larry
Alaska442
Mar 14, 2022 05:10 PM
mais18
Dec 3, 2018 08:38 AM
don71
Nov 26, 2018 06:50 AM
Sep 13, 2018 05:09 AM
dele
Jan 19, 2017 01:14 AM
