Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
LT1 Swap
Old May 18, 2019 | 03:48 AM
Trashylowrider's Avatar
LT1 Swap
I just bought a mid to late 90s LT1 327 going to rebuild it. I just want to know if it will bolt up to the factory transmission in my 85 Delta 88.
Old May 18, 2019 | 05:50 AM
edzolz's Avatar
No, unless you have a 200 4R overdrive with dual pattern bolt holes.
Old May 19, 2019 | 07:44 AM
Lonnies Performance's Avatar
FYI, they did not make a 327ci LT1. The 5.7 350ci versions did have a number 327 cast on the side of the engine.
They made a small 4.3L version of this also. These have a 4.3 cast into the block above the belle housing area.
It will only fit your current trans if it has a factory dual pattern trans or if your car originally had a 305 Chevy engine in it.
Old May 19, 2019 | 08:31 AM
It will also violate your transmission internally unless you beef it up. Why not keep your Olds with an Olds engine? Plenty of cheap Olds 350s around that you can build stout.
Old May 27, 2019 | 06:40 PM
mjrj's Avatar
Honestly if you're going the LT1 route use a 4L60E and use the stock computer to control it. Much easier than trying to use a TH250C/TH350/200-4R. If you want to keep the LT1 AC compressor you need to clearance the frame and front crossmember on the passenger side. The back of the compressor hits the frame.
CJG
Aug 14, 2016 08:21 PM
wrath
Mar 20, 2015 07:52 AM
ny to mi olds
Mar 31, 2011 06:46 AM
deltathunder
Sep 13, 2008 01:13 PM
joelow83
Jul 13, 2006 03:19 PM
