Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
2000 Dodge Dakota 3.9 to 5.9 swap
Old Oct 7, 2015 | 07:10 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Well, the sludged up 3.9 got starved for oil and is clattering bad. The rest of truck is in very good shape, trans pan was spotless when I changed the fluid, just over 200,000 km on it. I picked up a 185,000 km 5.9, with the throttle cable and partial wiring harness for $1000. I also picked up 2000 5.9 R/T computer, programmed to my Vin. I pulled the exhaust manifolds, making sure there were no seized bolts for future header swap. Going clean it and paint it next.
https://classicoldsmobile.com/forums...1&d=1444270173
Old Oct 11, 2015 | 10:22 PM
Next is matching the old set of MSD superconductor wires that were on my 403. Number one wire cracked near the boot twice due to overheating issues. Then install and wire up with the 5.9 computer. Setting the bands and changing the fluid on the 42RE also.
Old Nov 11, 2015 | 04:54 PM
3.9 ready to be pulled.
Turd on the floor
Old Nov 14, 2015 | 06:14 AM
V6 injector wiring top, V8 bottom
Very simple, common green with orange wire for power on #7 and #8 injector. Then grounded through the ECM, is supposed to be programmed to vin, on #2 and # 13 pin. Having the V8 harness will make it simple
Old Nov 15, 2015 | 01:10 PM
All the injector wiring and grounds a soldered and heat shrunk. I ran the #7 and #8 injector ground wires in a separate loom going to the ECM. Picking the two spots is easy considering there was two plastic plugs in the connector where they needed to go.
Old Nov 15, 2015 | 02:13 PM
wr1970's Avatar
Interesting project you have going!
Old Nov 15, 2015 | 04:46 PM
This truck was the right price, under 200K mileage, would have preferred a V8 Quad cab but they were 3 grand more. It was decent off the line with 3.92 gears but down right unsafe passing on the highway. I opened up the inlet on the air filter box and added an AEM dry flow filter. I also added a big body Dynomax Super Turbo muffler, unnoticeable inside but noticeable outside. Both made a good difference but my daughter over revved the sludged up 3.9, must have had a piece blocking the pick up, flickering oil pressure when she brought it back. With minor mods, factory y pipe is tiny, replace with JBA y pipe, probably headers, 1.7 roller rockers and tuner should reach 14's. I can hardly wait.
Old Nov 15, 2015 | 05:19 PM
wr1970's Avatar
Keep us posted.
Old Nov 18, 2015 | 05:43 PM
5.9 dropped in, sort of. I used the Durango mounts which also hook to the trans, passenger side fit fine. Drivers side won't drop down and if it does the motor will be too far forward on that side. I may just use the 3.9 mounts instead.
Old Nov 19, 2015 | 04:36 PM
Well my 3.9 mounts are different. The 5.9 mounts sit 1" back on the drivers side and holes are smaller on the passenger side, ask me how I know. I think it has to do with the mounts being off a 98 Durango. Dodge changed from the Dana 35 front axle to the 205 mm(8") in 2000 and the motor mounts attach to the diff. I would in a way like the Dana 35 to add a locker, now I have the mounts necessary to change, if I want.
Old Nov 19, 2015 | 04:46 PM
Tedd Thompson's Avatar
You will probably like everything but the gas mileage on that 5.9. On the best of days 13 is just about all I can get out of mine. Lots of power though. I'm glad the price of gas is down. Keep us posted... Tedd
Old Nov 20, 2015 | 05:27 AM
Thanks Tedd. I was maybe getting 20 imperial or 17 US out of the gutlass 3.9. Supposedly with the B&G Chrysler or Hemifever tune, should actually get better mileage than the 3.9 and even more power. I believe the SCT tuner is used by Hemifever and includes 3 custom tunes. I will get a 87 mpg tune, 87/89 octane towing tune and 91 octane racing tune from him.
Old Nov 23, 2015 | 05:41 AM
Getting the motor and trans lined has been a pain, hopefully tonight.
Old Nov 23, 2015 | 10:00 PM
Couple of bolts in the bell housing and mounts in place, finally.
Old Nov 28, 2015 | 01:35 PM
On the home stretch. I have to finish it this weekend due to a shorted out block heater burning the Olds powered 4x4 to the ground.
Old Dec 3, 2015 | 08:49 PM
It started and died a couple of times then wouldn't start again. Injectors stopped firing. Put the v6 ECM in and it ran somewhat. I think I will bite the bullet and get B&G Performance to do custom tune on the 5.9 R/T ECM I bought.
Old Dec 6, 2015 | 04:07 PM
Ran it in 6 cyl mode, good oil pressure, no leaks and topped up the fluids. Of course I should have checked the block heater, need to replace it. Didn't hear it working and had infinite resistance. The one in the 3.9 worked and it is easy to get at in the truck. Of course it means draining the antifreeze again.
Old Dec 23, 2015 | 02:14 PM
ECM on the way from B&G Performance, crossing my finger it fires up. Asked for a 87 top mileage/towing tune.
Old Dec 31, 2015 | 05:43 PM
ECM back, still no start, contacted them.
Old Jan 1, 2016 | 08:35 PM
I read in the manual that anti theft was an option, the ECM I bought must have it, mine truck does not. If they can disable it, I should be golden.
Old Jan 7, 2016 | 07:42 AM
Talked to B&G, under warranty except of course shipping, probably another $100 there and back. I never realized there was an anti theft option in 2000, probably the reason I have no fuel or spark with the V8 ECM, With the V6 ECM in, it fires right up but only have second gear with the shorted TCC/OD solenoid shorted out.
Old Feb 3, 2016 | 04:08 PM
Changed the transmission od/tcc solenoid and got the ECM back. Started right up on eight cyl but still had a check engine light but it needed gas so I took it for a drive. Still only one gear in limp mode, still the same code. Runs decent at least.
Old Aug 14, 2016 | 06:47 PM
Well my daughter blew both head gaskets and the intake pan was starting to go. I sat forever, good thing a cliff wasn't near by to throw it over. I fixed the head gaskets and intake pan jumped 7 and 8 off 1 and 5, since it was running on 6 cylinders. I finally got all gears by removing the trans relay and jumping two terminals. I also added two toggle switches to ground, on spliced into the OD, the other the TCC. I instantly had all the toward gears except OD which works with the toggle switch. Wow, what a difference. It will spin the tires hard enough to get wheel hop. I also added a big trans cooler that supposedly bypasses when cold. Just need a winter front and command start to finish. Finally!
Old Aug 14, 2016 | 09:05 PM
marxjunk's Avatar
id like to get one of those 5.9 throttle bodies for a mock up and experiment with, for a turbo project...they have Delphi AIC TPS and map sensors...i need one to see if i can make it work..
if you come up with an extra..id be interested..
Old Aug 14, 2016 | 11:01 PM
I may consider mods in the future, the throttle body is one of them. I have a 3.9 throttle body complete minus the tps.
Old Aug 15, 2016 | 07:42 PM
marxjunk's Avatar
ive been eyeballing one of these....
http://www.ebay.com/itm/291822855865...%3AMEBIDX%3AIT
ive been watching to get a stock junk one to see if it will work before i pop for one...id hate to spend the 200 and cant make it work...there are none on craigs and cant find any at pick and pull..they must have a high core value or have issues...i dunno..
Old Aug 18, 2016 | 06:28 AM
I still have all the gears but have codes galore, mostly for the trans and now it is down on power again. My noir light said the #7 injector was firing. Just idiling rough and slow acceleration compared to before. Maybe the TCC is sticking on?
Old Aug 21, 2016 | 09:08 PM
It is running better after the battery nearly went dead. Maybe the TCC unlocked? No miss and more power.
Old Aug 27, 2016 | 06:12 AM
Still lots of power, battery hold down in for the 1/8 mile track on September 3rd. I had to drain the anti freeze looked like ***** crud from doing the head gaskets, need water in there for the track anyways. This truck moves and is no harder on fuel than the 3.9 with twice the power. With a better muffler, air box mod, better filter and 3.92 sure grip, I am hoping for a 9.6 in the 1/8 mille. Traction will be the issue, will try 20 psi in the A/T tires and go around the water box.
Old Aug 27, 2016 | 07:34 PM
Well, no track this year. I am on the side of the road, there has to be a cracked head. So two new Magnum EQ heads it is.
Old Aug 29, 2016 | 10:16 AM
  #31
A thermostat did not fix it, the fail safe open up on the Motorad stat feature did work. it has to be a head leaking into the coolant. Head gaskets are holding for now, will putt around town for the winter with it. It will cost probably 2 grand Canadian by the time they are shipped and the exchange rate. I will go through Hughes, the one guy who went through Jeggs had a valve stick after 15 minutes run time. Hughes mentioned the guides sticking on heads without bronze guide liners, obviously true.
Old Aug 30, 2016 | 06:00 PM
  #32
marxjunk's Avatar
bummer...
Old Aug 31, 2016 | 01:03 PM
  #33
This truck has fought me every step of the way.
Old Aug 31, 2016 | 02:48 PM
  #34
marxjunk's Avatar
some just do that..i had this old 70 chevelle that was a decent car..but no matter what it was impossible to keep it running..it was a curse i swear...finally gave up and took a bath on it..but it was gone...believe me i tried to work thru it..and just what ever i did..it was broke..always broke..or id fix it and something else would take a crap..i had the trans in that thing 3 times..
i just dont give up..its in my nature
Old Sep 4, 2016 | 09:38 AM
  #35
I don't give up either. I just have too many vehicles. Even my Challenger being 6 years old has issues like needing a window switch, the weather strip for hood came apart, door needs adjusted etc. Little things but I have many projects.
Old Oct 13, 2016 | 01:52 PM
  #36
Well, I bit the bullet. I bought a pair of complete Ram EQ replacement heads, .028" head gaskets, all the top end gaskets, the thick aluminum plenum plate and bolts from Hughes. This should bump compression to 9.6 to 1 with better head flow.
Old Oct 18, 2016 | 10:14 PM
  #37
I received the gaskets, thick aluminum plenum plate and Ram EQ heads. Nice castings, bronze guide liners and improved springs from Hughes. They have nice flow numbers 233/188,, probably equal to or better than well ported #6 heads as cast and have material where it is needed for porting and crack prevention.
Old Oct 28, 2016 | 06:24 AM
  #38
Installed and running. Just need to get fresh gas and maybe bump the idle a bit. Stole the IAC of the 3.9 was idiling like **** and stalling, looks like it was stuck right in. Seems better now.
Old Dec 3, 2016 | 08:22 PM
  #39
Well after the truck just running shitty after the head swap, I found 2 issues. First it was running on 7 cylinders, number 8 had a wire off. Noticable miss, I guees so. Second is the reason the truck has run shitty on and off. I "upgraded" to a brass BWD cap, some upgrade. It never sat on the motor properly, wouldn't tighten down, pretty sure it was moving, causing shitty running. It got really bad barely running, I had a Champion cap, brand new. I found the rotor with the spring broken off. This cap tightened down all the way and replaced the rotor. No more bad missing or violent shaking in reverse. Finally!
Old Dec 10, 2016 | 05:54 AM
  #40
It had a little miss but other than that, ran great on a 3 hour return trip. I am going to check the cap and rotor again, plugs and put back on my MSD Superconductor wires I took off in desperation, currently a mismatched set. Either way, no over heating and good power. I am going to figure out mileage today.
