Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
68 Cutlass
Old Mar 10, 2024 | 09:06 AM
patg_225's Avatar
68 Cutlass
Good Morning All,
I want to start by saying, the picture really does this car justice. Honestly the car is in pretty good shape. I bought it in 2019.. Been working as a Contractor over the past years spending a lot of time in Iraq, Africa and plenty of other places. I'm back home and I want to do a Full off the frame restoration for this baby here. I'm sticking with the same color. The top is new, recently replaced that. Tires are new, found the wheels on Facebook lol. My main reason for this post is to get a bit of advice. Like I said, I'm going to do a total off frame restoration. I plan on putting this motor in the car ( hope the picture shows). Can you guys point me in the direction for the best rear-end, breaks, control arms, suspension and whatever else I may possibly need to ensure the car can handle this power and ride smoothly. Also, no, I'm not building a race car, but I do want the power, speed and everything else that comes with it. Better to have than not to have. lol. This will most likely be a cruising and car show type of car. Thanks in advance for the tips and recomendations.
Old Mar 10, 2024 | 10:50 AM
BackInTheGame's Avatar
Sharp ride; I love the color. Sorry, I don't know anything about an engine swap. I'm sure others will chime in.
Old Mar 10, 2024 | 11:02 AM
With that power level, you’re gonna need to massively reinforce the frame on that convertible to prevent it from twisting.
Old Mar 10, 2024 | 11:05 AM
Is the engine pictured the one that's in it?
Old Mar 10, 2024 | 01:07 PM
Bfg's Avatar
Bfg
The color will look good around Halloween
Old Mar 10, 2024 | 03:05 PM
patg_225's Avatar
The engine that is pictured is what I'm thinking about going with. As of now, it is currently LS Swapped with a 2001 5.3L.
Old Mar 10, 2024 | 03:12 PM
So "restomod," not restoration, right?
Best of luck.
Old Mar 10, 2024 | 03:26 PM
Loaded68W34's Avatar
If you can afford that engine, just go with a roadster shop chassis and be done with it. They will build you a frame with brakes, suspension, rear end, and can set it up so the motor will be a direct bolt-in. You can even go full IRS or cantilevered. You will probably be able to get a full pro-touring engineered frame/ suspension for less than the cost of that motor that will out perform anything you can do to your original frame. The link below is 68-72 chevelle.
https://roadstershop.com/chassis-and...8-72-chevelle/
hawks70
Jun 8, 2019 09:25 PM
c-towndave
Oct 10, 2011 01:34 PM
LaMaR-
Oct 15, 2010 12:06 PM
hamrick1229
Aug 10, 2009 07:51 AM
Wilson05
Feb 27, 2009 10:52 PM
