Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Never thought - I'm going LS
Old May 16, 2021 | 12:11 PM
COBRA2000's Avatar
Well my 70 olds w-30 conv is getting a brand new LS engine...I never thought i would do this, but with all the great reports of LS swap's, i pulled the trigger...This is a brand new LS engine being built from scratch...Should put out about 550-570 HP and 550lbs of torque..My 455 overheated a few weeks ago too 280 degrees!!!! I dont know what happened, but the valves are burnt and no blown head gasket..My mechanic did find 3 cylinders with antifreeze residue. So needless to say, this motor and heads will be for sale..This is a real W-30 block and heads.
Old May 16, 2021 | 01:42 PM
I moved you post to its own thread. Sorry to hear of your unfortunate mishap. IMHO, if the block and heads are original to that car, I would keep them.
Old May 16, 2021 | 02:01 PM
COBRA2000's Avatar
Thank you!!!
Old May 16, 2021 | 02:20 PM
70W-32's Avatar
If you get rid of the original motor, you destroy the value of the car as a W30.
Are you staying with EFI on the LS or swapping to carb . I see quite a few of these swapped LS cars for sale for far less than the owner spent to convert them. If you dont know modern electronic controls, you better make sure your mechanic does.
Old May 16, 2021 | 02:27 PM
COBRA2000's Avatar
EFI..I had the Holley EFI on the 455 and worked great!!! But im just at point in my life too where time is precious and i just don't have the time to be messing around with car problems..I work 12-15 hours a day, so on my time off i want car to run well and just enjoy it...But yes i have a shop here that works on these types of set ups...
Old May 16, 2021 | 02:30 PM
COBRA2000's Avatar
Here is the engine that is being built for me.... https://golenengineservice.com/lsx-c...mplete-engine/
Old May 16, 2021 | 02:35 PM
You're just funnin' us, right? Is April Fool's day late this year because of COVID?
Old May 16, 2021 | 02:42 PM
COBRA2000's Avatar
No my friend....It's pretty sad when you the wrecker's guy's name by heart...LOL
Old May 16, 2021 | 03:08 PM
vCode442's Avatar
Vincit qui se vincit
Eastman Kodak decided not to go forward with their own newly invented digital cameras, and instead stuck with film because it made them so much money at the time....
Don’t sell the original block and heads!
Old May 16, 2021 | 03:10 PM
70W-32's Avatar
Or Intake,Carb.,Distributor. Or the transmission
Old May 16, 2021 | 03:24 PM
COBRA2000's Avatar
I have those...
Old May 16, 2021 | 03:25 PM
70W-32's Avatar
Do you have a list of other parts you will need to complete the swap?
What trans do you plan on running?
Will your current fuel system be adequate to feed the LS?
You going with exhaust manifolds or headers?
You will need an accessory mount set up that clears the frame? (that includes the A/C pump, the altenator, and the power steering reservoir) Keep all your Olds stuff
Will the current radiator work?
Old May 16, 2021 | 03:31 PM
2blu442's Avatar
Your car to do as you wish. I do agree with the other guys if you don't need the money keep the original engine and parts with the car. Or consider purchasing a Cutlass convertible and selling the W30 complete needing an engine rebuild. Just my 2 cents.
Old May 16, 2021 | 03:38 PM
70W-32's Avatar
It sounds as if you can afford the whole swap, just hold onto all the Olds W30 parts, so when the car is passed on in the future, it will still retain the W30 value and provenance
Old May 16, 2021 | 03:40 PM
COBRA2000's Avatar
I have it all engineered out...I have the holley fuel pump and the becool radiator 3500cfm ....It will be headers...
Old May 16, 2021 | 04:12 PM
x2000. Factory W-30 ragtop and ditch the original drivetrain?🤯🤒
I would say please please to all of us Olds heads out here. Sounds like money is not an issue. Hold onto everything. That would be brutally sad.. 😪😔
I do get the why I really do. You will do it right too. I know you will. You have all the way already. Sure would like to see that original parts stay with that car. 🙏
Old May 17, 2021 | 07:26 PM
Lonnies Performance's Avatar
I have done quite a few LS swaps & builds. They run well & are typically very reliable.
Since the heads flow so well, you will be rewarded with good performance & mileage with a relatively small duration cam.
My latest is an LS3 / T56 Magnum with 4.10's in an S10.
It pulls hard to 6500 & still drives nicely through town in 6th gear at 1000rpm.
It's nice when you can take it to a car show on Sunday & then enjoy driving it over 200mi to work during the week in nice weather.
Look out for hidden expenses... sensors, wiring, tuning etc.
What front drive accessories are you planning? I've run the C5 Vette ones on many GM conversions with good results.
Kwik performance has a nice high mount AC kit if you need it.
Keep your factory stuff to preserve the value, but build your car to enjoy it.
You should be able to do the swap without cutting or permanently modifying anything.
Dropping a few hundred lbs. off the front won't hurt performance or handling either.
Remember the torque of your engine peaks rather high (4800), so do not gear it like a big block.
LS engines will happily turn 6000+ all day.so consider a rear gear around 3.73 to make it work well.
What trans are you planning to run?
Old May 17, 2021 | 07:47 PM
COBRA2000's Avatar
Smile
Thank you for the positive response!! I feel like like i've been getting CHEWED OUT!! But's that okay because i don't give a ... I want to drive my car without having any problems on a frequent bases...Front end will be Holley with AC..Transmission is 3 speed turbo-400..But i will upgrade to an overdrive trans in the future..I just want to get this thing rolling and drivable without problems...should be ready mid July????
Old May 18, 2021 | 07:08 PM
A lot of purists frown on modifications, but when done carefully, the originality can be returned.
I like old cars & appreciate history, but welcome anything that makes me want to drive a car more.
I've passed up countless opportunities of driving classic cars because of various mechanical shortcomings or fear of "ruining" them.
After looking at my cars sitting in the garage, I realized, why should I let them sit until I'm too old to enjoy them, so the next owner can enjoy them instead of me?
Look for a 4L80E now & get it all done in one sweep. Not entirely sure about the fitment in your trans tunnel, but you are missing a big part of the modern driving experience without the corresponding overdrive trans.
Have you looked into the proper Holley oil pan also?
Post some pictures of the progress & good luck with your build.
Old May 19, 2021 | 05:43 AM
COBRA2000's Avatar
Thank you very much..But i will look into the trans later on..But yes, i have the correct Holley oil pan...
Old Jul 4, 2021 | 10:59 AM
COBRA2000's Avatar
New engine has arrived..Official #'s...582-HP..567-TOURQ..This thing is a beauty...It goes for it's install next Monday July 12th...
Old Jul 4, 2021 | 11:01 AM
COBRA2000's Avatar
Here is the dyno test...
Old Jul 4, 2021 | 01:57 PM
Nice
Old Jul 4, 2021 | 04:13 PM
RetroRanger's Avatar
72 Olds CS
Pretty sweet. Ill bet the 12th cant come fast enough
Old Jul 4, 2021 | 05:02 PM
COBRA2000's Avatar
Nope..It's like Christmas...
Old Jul 4, 2021 | 09:17 PM
I think you are going to love that engine.
Old Jul 5, 2021 | 05:43 AM
COBRA2000's Avatar
Yulp..I can't sleep at night!! LOL
Old Jul 5, 2021 | 01:21 PM
I bet you are super excited. I am not an LS swap hater at all. I so get it. Like I said early in this thread that you would do it right. Looks like you are on it. Consistent reliable perfect for the street horsepower. Let alone the gas mileage savings.
Touchy subject maybe but what are your plans for the original drivetrain? You don't have to feel obligated to answer that. I was just curious.
Old Jul 5, 2021 | 04:10 PM
COBRA2000's Avatar
Thank you for the warm words...But i do want to sell the 455...It is a real W-30 with W-30 heads...Im told my valves are burnt..So it will need some work..I just don't what the asking price should be??? But i am keeping the turbo 400 trans....
Old Jul 5, 2021 | 07:02 PM
Keep the engine as it matches the car, you only have a number matching car once.
Old Jul 5, 2021 | 07:17 PM
  #31
COBRA2000's Avatar
I understand...But it's time to move on...
Old Jul 5, 2021 | 07:29 PM
  #32
No, you need to keep the original engine. It's not "time to move on" this isn't a relationship with a girlfriend. Put your Chevy engine in there if you must; do nothing to the original engine if you must, but Do Not Sell That Engine. That W-30 engine is very repairable, and it is what I would be doing in your situation. If you want to go LS, that's on you, and you need neither compliment or criticism from me on that, but I will criticize you if you knowingly sell the numbers matching engine away from a W-30, especially a saveable one.
Just put it on a dolly under the workbench for now.
Old Jul 5, 2021 | 08:05 PM
  #33
4+4+2=10's Avatar
How confident are you that you really have the original drive train? In this day and age, I can't imagine turning loose a known original engine.... Unless you know it isn't or your car isn't a real W30. You should let this soak a month or two before you do it.
Old Jul 5, 2021 | 08:15 PM
  #34
The engine adds 3-4x more to the value of the car than you can sell it for.
Old Aug 30, 2021 | 09:03 AM
  #35
So did you do this swap yet? Just curious.
Old Aug 30, 2021 | 09:09 AM
  #36
COBRA2000's Avatar
Nope...The oil pan got cracked in shipping!!! So now we are trying to find another one...They are on back ordered until NOV!!! UGH!!!!
Old Aug 30, 2021 | 09:20 AM
  #37
What pan are you using?
Holley 302-3?
Old Aug 30, 2021 | 09:29 AM
  #38
COBRA2000's Avatar
Holley 302-3?
Yes sir...302-3....My engine builder has a buddy in Wisconsin who thinks he may have one in his warehouse..So we will see?? May have to use the 302-2??
Old Aug 30, 2021 | 12:25 PM
  #39
gs72's Avatar
72Cutlass S
I’ll bet your glad you posted about your engine swap. Next they will be calling for a lynching.
Old Aug 30, 2021 | 12:48 PM
  #40
COBRA2000's Avatar
Why?
