Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
I may have put a hurt on my ricer Miata NA6 engine
Old Jan 26, 2018 | 03:17 PM
Tedd Thompson's Avatar
Miata's have great little engines but they don't take over heating well at all. I had a secondary radiator hose cut at the clamp and split and lose fluid. I didn't catch it till it was pegged on hot, big bad on my part.My thoughts are that I now have a blown head gasket but It doesn't act like a bad gasket. No water in the oil, no oil in the water, I see no leaks or steam at the engine or tail pipe, heater core is dry yet it will take a pint of fluid about every 75 miles and will gradually sooner or later heat up if I don't add fluid. Every blown head gasket I have been involved with has super heated the water in a few minutes and no way could I drive a hundred miles before it would show hot. But then again the water is going some where and the head gasket is my first guess.
Plugs were just changed a week or so before this happened, they look new and all the same because they are very new.No amber color at the tip, no steam clean look. I don't have a bore scope or I would take a look at the piston tops for the steam clean appearance. What else could be done that would pin point this issue I'm out of ideas..... Tedd
Old Jan 26, 2018 | 03:26 PM
2blu442's Avatar
How is your other hoses? Odds are they didn't go bad at the same time, but I had something on my daily driver that was making the reservoir go dry. One day I squeezed the hose in just right place and saw a tiny stream squirt out of a pinhole. Never left a puddle on the ground, but under pressure it was likely venting through this pin hole.
Old Jan 26, 2018 | 03:36 PM
m371961's Avatar
Pressure test? Maybe a small external leak at temp and while driving that burns off without evidence. Bore scopes are not so expensive anymore.
Old Jan 26, 2018 | 07:10 PM
redoldsman's Avatar
Proud Viet Nam Veteran
You can get one pretty cheap from Harbor Freight.
Old Jan 26, 2018 | 08:25 PM
I have a complete set of hoses ( I think 9 in all) that are setting in a box on the shelf with the radiator and cap to match waiting for me to change them out, I'm a little late, bad timing on my part.
I might swing by Harbor Freight tomorrow and see whats up there. Buying tools gives me a up lift I can use anyway.... Tedd
Old Jan 26, 2018 | 08:26 PM
stevengerard's Avatar
is there a high point in the system that may have some air bubbles in it. Thus the system is not filled all the way?
Old Jan 26, 2018 | 09:48 PM
Yea,I know about burping Miatas sometimes they are hard to get full. Most times if you jack or lift the front a foot or so that troublesome air bubble will escape and the radiator will take a quart or so extra water. But I have something different going on here I believe.. More to follow when something different happens... Thanks all for your ideas and help.... Tedd
Old Jan 27, 2018 | 03:49 AM
gs72's Avatar
72Cutlass S
These things work great. You can also pull a vacuum on the cooling system with it and see if it bleeds up indicating a leak.
http://www.tooldiscounter.com/ItemDi...CABEgKgxvD_BwE
Old Jan 27, 2018 | 07:51 AM
Just a quick after thought, I noticed that the return overfull tank never seems to change (stays the same level) no matter how much liquid is in the radiator. Wouldn't that be a sign than the system has a leak somewhere?.... Still could be a blown head gasket though that is defiantly a leak.No air bubbles at the radiator cap. Typing out loud here.... Strange issue... Tedd
Ps I'm off to Harbor Freight.
Old Jan 28, 2018 | 01:07 AM
Ozzie's Avatar
Depending on how the head gasket failed, a compression test may reveal something.
In the past, Harbor Freight's inspection camera's probe was too big to go through a 14mm spark plug opening.
Old Jan 28, 2018 | 06:02 PM
Yellowstatue's Avatar
Fastest check...change the rad cap!!!
evans_78
Aug 29, 2011 10:32 AM
gearheads78
Sep 29, 2010 08:29 PM
made in the usa
Feb 16, 2010 09:13 PM
gearhead1218
May 26, 2009 05:22 PM
Redog
May 23, 2008 09:50 AM
