Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
LS or SBC Swap into 62 Skylark.
Old Dec 14, 2017 | 04:15 PM
Reebz's Avatar
This is my first post and its not even an Olds question, plus I'm putting the "wrong engine in it" what nerve.
OK guys I have a 62 Skylark (Y Body) similar to the Olds. I want to put a stroker 383 or LS into it.
Does anyone have experience with this? Its going to be a lot of work,cutting but I want to try. Any advice would be great.
Old Dec 16, 2017 | 09:59 AM
nonhog's Avatar
Registered car nut
I sold parts to a local guy with a 350 Chevy powered 63 Cutlass so it can be done. Never saw it (other than pictures)
Old Dec 16, 2017 | 10:22 AM
Reebz's Avatar
Thanks. I think I'm going to replace the cross member and go with a mustang II rack.
Old Dec 16, 2017 | 01:43 PM
garys 68&72's Avatar
Check over at LS1tech conversions forum. Might be something similar there with the LS info.
Old Dec 16, 2017 | 02:52 PM
Reebz's Avatar
Good Idea
Old Dec 16, 2017 | 03:26 PM
76olds's Avatar
Hookers under Hood
Sounds like it will be a fun project! What brings you to an Oldsmobile site?
Eric
Old Dec 16, 2017 | 07:48 PM
Reebz's Avatar
Eric
61-63 Y Body Olds and Buicks have the same suspension. Hoping to find some advice.
Old Dec 16, 2017 | 09:44 PM
76olds's Avatar
Hookers under Hood
Post some pics if you get time, Olds or not I like them all.
Cheers
Eric
Old Mar 2, 2018 | 06:08 AM
1971 cutlasssupreme's Avatar
LS power,,, super reliable, great power potential if ya want more, doesn't fill the garage with gas fumes when running,,,, Something else to think about, if its an "only special occasion" driver, the LS is great in that it runs good even after sitting long periods of time. Seems the carburetor/Point ignition systems run better when being used consistently. Obviously its your choice what you want between the frame rails so if you don't mind messing with carb/ignition tune ups ect, go with the old school power.
Old Mar 2, 2018 | 06:36 AM
redoldsman's Avatar
Proud Viet Nam Veteran
If I were doing that much work I think I would do the LS.
simpleold
Non-Olds Engines
22
Jun 17, 2016 05:13 AM
Johnny Cage
Non-Olds Engines
Apr 8, 2013 02:24 PM
kern84
Non-Olds Engines
39
May 27, 2012 06:54 PM
arnoldjr
Sep 8, 2011 07:12 AM
Tony Daytona
Jan 27, 2009 07:25 PM
