Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
65 230 chevy
Old July 10th, 2016, 06:08 PM
markmag's Avatar
Question 65 230 chevy
hi, was woundering why my 230 just started blowing oil from the dipstick today..I only changed the valvecover & cap?
markmag is offline
Old July 10th, 2016, 07:01 PM
Is the PCV hooked up and working?
oldcutlass is online now
Old July 10th, 2016, 07:47 PM
Proud Viet Nam Veteran
redoldsman's Avatar
X2 on Eric's comment.
redoldsman is online now
Old July 10th, 2016, 09:49 PM
Sugar Bear's Avatar
X3, if it has a PCV system confirm that it is the correct PCV valve and that it has vacuum. Was it particularly sludged under the valve cover? Wondering if a baffle or port inside the valve cover to the PCV is plugged.
If not equipped with PCV check for a plugged breather.
Next is defective rings, do a leakdown test preferably, if not a leakdown then a compression test.
Keep us posted!
Sugar Bear is online now
Old December 2nd, 2016, 04:20 PM
markmag's Avatar
thank you, I didnt have enough vac on it,I moved it from under the air cleaner,to manifold vav,and put a breathable iol cap on too..;..
markmag is offline
Old December 2nd, 2016, 07:05 PM
Glad you got it worked out.
TOONLOVESCHERYL
February 4th, 2016 06:30 AM
joepenoso
July 16th, 2012 08:48 PM
e129745
May 12th, 2012 03:40 AM
Super88inWilm
March 30th, 2006 04:32 AM
crank.it
May 31st, 2005 05:39 PM
Quick Reply: 65 230 chevy
